EG hatch with h22 help!!!!!!!!!!!!!
Old Aug 2, 2006 | 06:27 PM
EGG_y0's Avatar
Default EG hatch with h22 help!!!!!!!!!!!!!
hey i have a 92 civic with a h22 and it is not starting. it will crank over i also dont hear the fuel pump turn on. i just got a new fuel pump and it didnt work... and i also got a new main relay and still nothing. please someone help me out!!!!
Old Aug 2, 2006 | 08:06 PM
Cvic90's Avatar
Default Re: EG hatch with h22 help!!!!!!!!!!!!! (EGG_y0)
Does your check engine light come on when you turn the ignition on for about 3 seconda then turn off? if so, the ECU is good and the may have a wiring problem. If not check, the ground on the thermostat housing, it's the most common problem. If it does, do you have a spare odb1 ecu (can be from any honda) you can plug in and turn on the ignition to listen for the fuel pump to turn on. If it does turn on with another and not the H22 ecu. the H22 ecu has a problem.
Old Aug 3, 2006 | 07:37 AM
EGG_y0's Avatar
Default Re: EG hatch with h22 help!!!!!!!!!!!!! (Cvic90)
ill go and check that ground and no i dont have a obd1 ecu but how could it be that when it was just working a few days ago?
Old Aug 3, 2006 | 07:41 AM
lucky4586's Avatar
check you Fuel filters and fuel lines for blocks in them and check if your getting spark
Old Aug 3, 2006 | 08:26 AM
EGG_y0's Avatar
Default Re: EG hatch with h22 help!!!!!!!!!!!!! (lucky4586)
well i got the fuel pump to turn on now but its still not starting and now the check engine light comes off then turns off
Old Aug 3, 2006 | 08:46 AM
Stoich EG2's Avatar
how many grouunds do you have? i found that h22's are very needy of ground wires
drivingshadow
Mar 31, 2015 03:46 PM
nightrider93ex
Mar 12, 2008 08:33 AM
n2ob16hatch
Sep 20, 2006 07:37 PM
y0whuddupb
31
Aug 9, 2006 01:16 PM
92acclude
Jan 31, 2005 05:33 AM
