EG civic knuckle same as DC2 / ITR ?
Old Aug 2, 2006 | 05:56 PM
bennjamin@ozhonda.com's Avatar
Default EG civic knuckle same as DC2 / ITR ?
hi all. Quick one...
Is a EG knuckle the same as a ITR ?
I have ITR caliper + rotor setup but the knucles are bent ~ will this setup (after pressing out the bearing etc ofcourse) fit onto my stock EG knuckle ?
thanks again Ben
Old Aug 2, 2006 | 06:03 PM
EL Vap133's Avatar
Default Re: EG civic knuckle same as DC2 / ITR ? (bennjamin@ozhonda.com)
Depends on what model EG you have....
Old Aug 2, 2006 | 07:14 PM
BlueIntegraBoy's Avatar
92-95 Civic EX ABS had the same knuckle as the non-ITR Integras. ITR knuckles are different.
Old Aug 2, 2006 | 08:14 PM
Default Re: EG civic knuckle same as DC2 / ITR ? (BlueIntegraBoy)
I have a aussie delivered 1992 EG5 Si (d16a8/ZC).
Let me reiterate ~
Will the DC2R calipers / brake fit onto a EG civic knuckle ?
Old Aug 2, 2006 | 08:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bennjamin@ozhonda.com &raquo;</TD></TR><TR><TD CLASS="quote">I have a aussie delivered 1992 EG5 Si (d16a8/ZC).
Let me reiterate ~
No, not without making new caliper brackets to space the caliper further away from the hub.
Old Aug 2, 2006 | 08:49 PM
EL Vap133's Avatar
Let me reiterate ~
No, unless they are from an EX EG with the 10.3" Rotors.
Old Aug 2, 2006 | 09:30 PM
Default Re: EG civic knuckle same as DC2 / ITR ? (EL Vap133)
i intend to have DC2 99spec ITR rotor + caliper combo on my EG civic ~
it seems the only way is to use a EG6/DC2/ITR knuckle OR use a spacer to fit the combo on my stock knuckles ?!
Old Aug 3, 2006 | 12:25 AM
JEM MotorSports's Avatar
FACT!!!, THEY ARE NOT THE SAME.
I have Spoon Calipers on a 4x100 set up. After a weekend of test fitting and a little R&D we concluded the only way to properly install Spoon calipers on a U.S. spec "EG", you must swap out and replace with DC knuckles. Just keep in mind, when purchasing new bearings, BUY DC BEARINGS.
Reason being, the mounting points/holes for your new upgraded calipers are a few millimeters off your existing "eg" knuckles. Attempting to line up your new calipers to your existing "EG" knuckles will not align.
We also attempted to use '99-'00 Civic Si ("EK")knuckles and failed as well. The mounting holes on the '99-'00 Civic Si align but do not give enough clearance when you attempt to assemble the entire braking system together.
FYI - A true Jap Spec RHD EG SIR model will come factory with the required knuckles. No fuss or replacement what so ever. It's just the way they made them in Japan... lucky f**kers. LOL
This would make it a 2nd confirmation from someone on HT.com
Hope the info helps.
I understand you're doing an ITR brake upgrade and I did a Spoon brake upgrade but the similarities between the two are in the alignment of the mounting holes.
...I found some pics which may help you too.
Modified by JEM MotorSports at 1:50 AM 8/3/2006
Old Aug 3, 2006 | 09:03 AM
spooned civic's Avatar
yes as stated above it is not a direct fitment.
yet it is possible to be installed using the usdm eh3 nuckles. as i have done it to my eh3.
ABK
Sep 6, 2005 05:28 PM
ILoveMyVTec
May 18, 2005 07:54 AM
DerangedEG
Nov 18, 2002 08:24 AM
ernie
Aug 14, 2002 03:40 PM
