Horrible alignment issue after rear disc conversion!
Old Aug 2, 2006 | 04:07 PM
Ex Member's Avatar
Default Horrible alignment issue after rear disc conversion!
I thought it would be a little off but wow the steering wheel is so crooked its like 90 degrees different. Is this normal btw I also change my suspension at the same time.
Old Aug 2, 2006 | 04:25 PM
slowcivic2k's Avatar
Default Re: Horrible alignment issue after rear disc conversion! (Turblow.Com)
make sure the toe in the back is correct, there are small notches below the compensator arm to adjust this, also, your thrust angle might be off because of the differing toe angles, ideally, they should be 1/16" to 1/8" toe in, this will correct a loose rear, this cant be done more accurately without an alignment machine, but can be adjusted easily until it suits you, which is how I did mine, find your old bolt holes, and match them as well as you can, and use that as a starting point. if you need more help with how to do this, post back.
Old Aug 2, 2006 | 04:26 PM
BlueIntegraBoy's Avatar
How can your front alignment be off when you only did a rear brake conversion? Anyways, get your car aligned and you should be good.
Old Aug 3, 2006 | 11:23 AM
Ex Member's Avatar
Default Re: Horrible alignment issue after rear disc conversion! (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">How can your front alignment be off when you only did a rear brake conversion? Anyways, get your car aligned and you should be good.</TD></TR></TABLE>
I also did a full coilover swap .
Old Aug 3, 2006 | 12:00 PM
EL Vap133's Avatar
Get an alignment.
Andrew14
Jun 14, 2010 09:27 AM
Chris Crane
Nov 12, 2008 07:57 PM
fraknstien
Mar 7, 2006 08:06 AM
eghatchproject
Mar 16, 2004 07:05 AM
eghatchproject
Jan 17, 2004 06:14 PM
