resistor for o2 heater
Old Aug 2, 2006 | 03:48 PM
btotherizzle's Avatar
Default resistor for o2 heater
I just purchased a plx m300 looks nice! I will be using it as my only sensor. I understand fully how to wire it and all that jazz. What I can't find is a 20ohm 10 watt resistor. I am in Oakville Ontario if anyone has any info I would greatly appreciate it. I have called a number of the usual place and the closest I've gotten is 3/4 watt,wtf? All these threads on here say just go down to the local radioshack, I called the new canadian radioshack location and the guy joked that he could only help me if I'm looking for low quality electronics.
Please help.
Old Aug 2, 2006 | 05:18 PM
jeremydde's Avatar
Default Re: resistor for o2 heater (btotherizzle)
http://www.active-tech.ca/b2c/...0W022
Located in vancouver, but maybe there is an Active near you? There is an active in Toronto which should be close to you.
Old Aug 2, 2006 | 07:20 PM
thank you.
Old Aug 2, 2006 | 10:38 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (btotherizzle)
If you chip your ECU and use a program like Crome, you can simply turn the heator part off.
Old Aug 3, 2006 | 03:50 PM
I have hondata but no laptop. Can I just leave the o2 hooked up minus the signal wire and let it hang? If I did this I would still have a load on the wires and no cel?
Old Aug 4, 2006 | 01:34 PM
no input?
Old Aug 4, 2006 | 01:40 PM
jeremydde's Avatar
That should work, although seems pretty silly when you could just turn it off in the ecu and be done with it for good. Look in your area for someone who has the capability to turn it off for you.
ochumi
Oct 25, 2018 10:14 AM
Infamous war
Jul 7, 2012 11:51 AM
Turbo O
Engine Management and Tuning
Oct 6, 2008 03:26 PM
THC07
Jul 6, 2006 02:02 PM
safe driver
Mar 3, 2003 01:19 AM
