Cable tranny questions
i got a 91da. i just converted it to manual and hooked up a 92-93 ys1. i know all b series tranys are pretty much interchangable. would i be able to keep my same clutch assembly if i switched over to a Si cable trans or would i have to change the clutch assembly? also if i were to move over to hydro trans, would it hook upa nd work with my obd1 b18a, and what would be need to complete it? when i did the conversion i had to frabricate a way for the manual tranny mount to bolt up to the subframe instead of spot welding the auto bracket off and welding the 5spd bracket on.
my 2nd gear grinds around 4900/5k rpms and im also lookin at getting somethign with a littlemore get up, i plan on either lsv/t or a gsr swap later on down the road i still ahve to get the blueprints for my monster worked out. anyhelp would be greatly appriecated and if someone could also give me a link to a page wit the tranny codes, gear ratios, and what not since im having trouble finding it through the search function.
What would you also recommend if i were to stay either all motor ls or lsv/t....Si?GsR?C/Itr?
D16Y7EJ1
Dec 15, 2012 06:11 AM
viking-101
Jun 26, 2011 07:11 AM
95 vtec
Nov 14, 2006 08:35 PM
