92-95 civic Rear disk swap question.. Need to know about Suspension..
Old Aug 2, 2006 | 07:13 AM
uvamosk's Avatar
Default 92-95 civic Rear disk swap question.. Need to know about Suspension..
I just need to know if the 94+ integra rear trailing arms bolted to a civic makes any diffrence in suspension and handling geometry..? I want to autocross/Street drive the car and just want to know if these will cause any problems with that or if they are just bolt on and act just like the car came with them on it..
Thanks
Old Aug 2, 2006 | 07:39 AM
LowSlow93Sol's Avatar
Default Re: 92-95 civic Rear disk swap question.. Need to know about Suspension.. (uvamosk)
You may want to try the suspension forum.
Old Aug 2, 2006 | 07:55 AM
24TEN's Avatar
PHANTOM MENACE
same thing, no problems or changes will occur IF you just swap the trailing arm only. not sure about the control arms. i did the same swap with my 91 hatch using 93 integ rear brakes and the arms are different lengths.
Old Aug 2, 2006 | 08:09 AM
BlueIntegraBoy's Avatar
The trailing arms are the same, as with the LCAs, so you won't mess anything up.
andyfee
Jul 29, 2008 08:38 AM
supdawg2
Aug 19, 2004 09:51 AM
hatchback12
Jul 19, 2004 04:49 PM
90civichbsi
Jul 10, 2004 08:30 AM
