OBD0 b16 into delSol w/obd1 harness; Plug unused??
Old Aug 2, 2006 | 02:14 AM
delsol revolution's Avatar
Default OBD0 b16 into delSol w/obd1 harness; Plug unused??
Hey all. I am using an obd0 b16a block with the delSol dohc VTEC harness. I have a question about the wiring;
All sensors are correctly hooked up, except for the leftover plug, and the 'jerry-rigged' one.
I seem to have an unused plug leftover (colors= Yellow/BL & Red). Is this correct??
Also, someone 'jerry rigged' this. I suspect it is for the oil pressure sensor/sender on the back of the block??? (Wire color = Yellow/Red stripe)
Old Aug 2, 2006 | 02:19 AM
fmrprojects's Avatar
Default Re: OBD0 b16 into delSol w/obd1 harness; Plug unused?? (delsol revolution)
just use a connector and hook up the single wire to the oil pressure switch. the other oneis the evap purge solenoid. the jdm b16 doesnt have that solenoid so just leave it. it will be fine
Old Aug 2, 2006 | 02:21 AM
Default Re: OBD0 b16 into delSol w/obd1 harness; Plug unused?? (fmrprojects)
Thanks man, that's what I thought, but just needed to make sure.
aeon117
Aug 12, 2011 02:41 PM
thegooddoctorceretti
10
Aug 30, 2007 08:36 AM
teg4life
Oct 14, 2004 11:22 AM
