Wirein!! 96 civic swap with jdm b18c
Old Aug 1, 2006 | 11:43 PM
Eli Mac 67's Avatar
Default Wirein!! 96 civic swap with jdm b18c
Just got a 98 jdm b18c out of a type r intagra and tryin to put it in a 96 civic ex...but the wirein harness dont go with the car...anyone did this swap or know what to do? i got the full engine swap but i dont know if i have to combined the 2 wirein harness to make one?
Old Aug 1, 2006 | 11:45 PM
axtran's Avatar
Don't start hacking that wiring harness up. The harness is reversed since the JDM one is for RHD. What you need to do is figure out what plugs on your stock harness will work, and port over the ones you need. Wire extension and lots of crimps (and or soldering alloy and heat-shrink) is necessary. Don't hack job your car, it will take a process but as long as you're patient it will be easy and possible. Check FF-squad.com to see some nice and helpful diagrams. Good luck.
Old Aug 2, 2006 | 12:26 AM
Eyal 951's Avatar
Default Re: (axtran)
wirein? Did you people go to school?
Old Aug 2, 2006 | 05:56 PM
Eli Mac 67's Avatar
Default Re: (Eyal 951)
no, schools over rated we live in iglos and ride our dog sled...sorry i dont live on the computer and make sure everything is corrected when i type ...
thanks for the info
Old Aug 2, 2006 | 06:08 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran &raquo;</TD></TR><TR><TD CLASS="quote">Don't start hacking that wiring harness up. The harness is reversed since the JDM one is for RHD. What you need to do is figure out what plugs on your stock harness will work, and port over the ones you need. Wire extension and lots of crimps (and or soldering alloy and heat-shrink) is necessary. Don't hack job your car, it will take a process but as long as you're patient it will be easy and possible. Check FF-squad.com to see some nice and helpful diagrams. Good luck.</TD></TR></TABLE>
listen to this guy...get somebody who knows how to do the wiring...
Eli Mac 67's Avatar
thanks, ya those diagrams help, tell ya how it works out in a few days when i get days off work, so i can sit down and do it
Old Aug 2, 2006 | 06:49 PM
F20Cteg's Avatar
Default Re: (Eli Mac 67)
Whenever you swap in a motor, it is almst always 100x easier to use the harness from the car. Just extend shorter wires and add the other wires you need. You can cut off the loom and move wires around too. Then wrap it back up and it will look really clean.
The only time it is not when you are swapping say an OBD1 GSR into an OBD1 Civic. Then the harness from the GSR whould be better since it has all of the VTEC, VTP, etc wires included and the harness plugs directly into the stock civic harness from the firewall.
93EssEYE
Jun 5, 2011 08:19 PM
jdmstyleEJ6
15
Feb 4, 2010 09:40 PM
1HotHonda
Aug 2, 2002 05:14 AM
