Will the tanabe racing madallion work with turbo????
Old Apr 23, 2002 | 05:00 PM
MysteriousGSR's Avatar
Default Will the tanabe racing madallion work with turbo????
I was just wondering if this would work with a turbo setup???
Old Apr 23, 2002 | 05:31 PM
phase12gsr's Avatar
Default Re: Will the tanabe racing madallion work with turbo???? (MysteriousGSR)
it should, but the piping might be a bit too small for a turbo application. (isnt it 2.25" or is it 2.5"?) most turbo setups will want at a straight 3" piping.
Old Apr 23, 2002 | 05:39 PM
TurboIntegra's Avatar
The piping is 60mm (2.36"). So it is a little small for a Turbo application. It will work however just not to the full potiential of a 3" system.
Haveing owned 3 Turbo Integras I would have to recommend 3" downpipe, NO CAT, and 3" EXHAUST as one of the best mods I did while turbo.
Old Apr 23, 2002 | 05:53 PM
Default Re: Will the tanabe racing madallion work with turbo???? (TurboIntegra)
thanks alot i think i will have a muffler shop make me a custom 3in piping then also where did u get the down pipe from and how much was it
Old Apr 23, 2002 | 08:09 PM
MrFatBooty's Avatar
Some member here (I think) makes a 3" downpipe for Drag/RevHard style kits.
I personally would say run a 3" Carsound cat rather than a test pipe, they flow about the same and you won't be spewing nasty smog out of your tailpipe.
Thermal makes a full 3" system if you would rather go that route instead of some custom pipes.
[Modified by MrFatBooty, 5:09 AM 4/24/2002]
Fred931931
May 26, 2008 12:33 AM
namm
Dec 21, 2006 10:07 AM
blackriceman
May 5, 2004 06:41 PM
X2BOARD
Oct 9, 2001 10:42 PM
