Suspension & Brakes Theory, alignment, spring rates....
INGALLS Question
Old Aug 1, 2006 | 09:57 PM
crj_lll's Avatar
Default INGALLS Question
I am installing a full set of ingalls camber kit mounts on my 1992 prelude 4WS. I have the 35730 Rubber Bushing version. I have heard of alot of squeaking from the ingalls kits. I am wondering if they are speaking of the rubber version or the polyurethane version. Has anyone had squeaks from the rubber ones and if so, how did they handle it?
Old Aug 2, 2006 | 06:58 PM
crj_lll's Avatar
Default Re: INGALLS Question (crj_lll)
Old Aug 2, 2006 | 08:45 PM
Miracle's Avatar
Since polyurethane is pretty stiff, you will need to lube it up with a white grease before installing them to keep the squeaking down to a minimum. Im not sure what TYPE of grease it is though, as the tube I got with my sway bar wasnt labeled anything but "Lubricant"
Old Aug 3, 2006 | 09:28 PM
crj_lll's Avatar
Default Re: INGALLS Question (Red_EM2)
Thanks for the reply but I do not have the poly version. I have the rubber version. I am asking if all the comments about squeeking all over this site are about the poly version or the rubber version?
Old Aug 7, 2006 | 11:58 PM
Groove_D's Avatar
How low are you going?
Old Aug 8, 2006 | 12:13 AM
crj_lll's Avatar
Default Re: INGALLS Question (Groove_D)
I am installing an set of Eibach PRo Kit Lowering Springs so that is 1.7 / 1.5 I beleive but the clearance in appliction is almost non-estant and I do not like the change in cabler of the wheels without the kit.
SIDreamer
Feb 28, 2011 07:52 AM
meagainsttheworld
Jul 9, 2007 08:42 PM
non-VTEC
May 18, 2003 05:13 AM
justagsr
Feb 28, 2002 08:40 AM
