what intercooler piping will work and you can keep your jdm fog lights???
i have searched nothing came up maybe I was typing it wrong I have heard on here that you can keep your fog lights but which piping will work for this to keep your jdm fogs???
for a 92-95 eg with oem foglights. there is 2 ways to make the intercooler and piping fit. one would be to get a welder to cut off the inlet and out let and reweld them upside down. then the piping will have to route over the foglights.
there is an intercooler that already has this done but i dont remember that make.
the other option is to use some small *** piping, like less then 1.5 inch which it totally pointless.
and i just thought if you use a side mount or top mount intercooler, the piping will be routed differently. but i dont recommend a top mount and have only seen small turbos use side mount intercoolers. mostly its a homemade kit.
Otherwise get a backdoor intercooler. You should have enough room on passenger side to work around that foglight.
yea i have similar setup ill post a pic later my intercooler i think i got my intercooler from same guy its 31in long from end tank to end tank 6in tall and 3 1/2 in wide 2.5 inlet and outlet
crxsiperf
May 6, 2005 10:11 AM
BlackB18CTeg
Jun 28, 2003 11:21 PM
