Tps code questions,can it be adjusted?
Old Aug 1, 2006 | 09:25 PM
skiracer8148's Avatar
Default Tps code questions,can it be adjusted?
my car is throwing a tps code.when i start the car it idles normal and then as soon the check engine light comes on it idles at like 1200.my car is also sputtering under 3000 rpms is this also becuase of the tps?so i know that all D and B series have the same tps.i was reading a topic where it said that the tps has to be moved around and read with a meter,should i just replace my tps with one from the junk yard or try to adjust mine?
Old Aug 1, 2006 | 11:04 PM
Slopoke's Avatar
Default Re: Tps code questions,can it be adjusted? (skiracer8148)
Adjust it, then reset your ecu.
If its still throwing a code, replace the sensor.
Old Aug 2, 2006 | 12:01 AM
qfast817's Avatar
Default Re: Tps code questions,can it be adjusted? (Slopoke)
i have a tps sensor for a gsr for 15 shiped
Old Aug 2, 2006 | 03:26 AM
no thanks i just had to collaborate mine works fine
superhatchbackbros
Apr 2, 2008 06:22 AM
REDREXMANB16
Nov 23, 2006 09:54 PM
shabam
Oct 23, 2006 08:31 AM
shabam
Oct 23, 2006 07:14 AM
psegs80
Jul 15, 2005 05:07 AM
