900 RPM squeek
Old Aug 1, 2006 | 09:05 PM
Voodooboy520's Avatar
Default 900 RPM squeek
This is happening more and more these days. At first, this squeek only happened when the ac was on and the clutch was slipping (going into first). Tonight, however, I was just screwing around, and it seems that if I put it in third going like 10 and go from 500 rpm to 1k, it squeeks around 8 or 900 rpm. Its in the engine bay, so I cant really see whats going on. My AC tensor bearing makes some weird noises when I first start the car in the morning, could this be it?
Old Aug 1, 2006 | 09:52 PM
Burlyirishdude's Avatar
Default Re: 900 RPM squeek (Voodooboy520)
check your belts bro...Squeel usually means..
) too tight
)too loose
Check a/c belt and tighten or loosen until squeels dissappear.
Old Aug 1, 2006 | 10:25 PM
RCautoworks's Avatar
Is it coming from the belts ? If you can have someone rev the engine, and if it starts making noise, squirt the belts down with water, when the noise stops you found the problem
Old Aug 2, 2006 | 08:41 AM
Its weird, its only when the car is in gear. My transmission is being gayer than usual (its getting harder to get it into gear), so I think I may be low on fluid. I know the shift linkage seal is leaking.
I'll check out the belts though. Thanks guys.
RobRyan0927
Honda Civic (2001 - 2005)
Sep 24, 2010 07:52 PM
sauljhernandez
Nov 7, 2008 10:28 AM
redline5th
16
Sep 18, 2007 11:16 AM
B18poweredhatch
Jan 29, 2002 03:26 AM
