Need help guys 235/40R17 on 17 x 8 48mm offset 5th gen lude
Old Aug 1, 2006 | 08:56 PM
ekim952522000's Avatar
Default Need help guys 235/40R17 on 17 x 8 48mm offset 5th gen lude
I need to know if this will work guys
17 x 8 48mm offset rota torques 5 x 114.3
235/40r17 falken rt-615's
98 prelude
I will be ordering these at 5pm tommorow and would love to know that they fit for a fact. I know alot of thanks get thrown around on honda-tech but I would really appreciate it if someone could help me out.
thanks
Old Aug 1, 2006 | 09:30 PM
bigj505's Avatar
Default Re: Need help guys 235/40R17 on 17 x 8 48mm offset 5th gen lude (ekim952522000)
17 x 8? I have 18 x 7.5 and the rear wheels are very close to the well. I would not suggest it, but I am not definite that yours will not fit. My offset is +42 if that helps at all.
My set up is:
18 x 7.5" +42 offset Racinghart CR single Piece
215/40/18 Nitto Neogen Tires
Tein Super Street Coilovers W/Pillowball Mounts (dropped pretty low)
Old Aug 1, 2006 | 10:41 PM
HxClude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekim952522000 &raquo;</TD></TR><TR><TD CLASS="quote">I need to know if this will work guys
98 prelude
thanks </TD></TR></TABLE>
it should fit as long as your drop is no lower than 1.5" 235/40/17 on a +48 17x8 wheel is a known fitment for the Prelude. I've seen it done with Toyo t1s and a few others but never the Falken (which is slightly wider). You'll need to trim the tabs in the rear and hopefully you have a stiff rear suspension
Old Aug 2, 2006 | 06:29 AM
Default Re: Need help guys 235/40R17 on 17 x 8 48mm offset 5th gen lude (HxClude)
What tabs would I need to trim?
Right now the car is at stock ride height.
Old Aug 2, 2006 | 07:37 AM
HxClude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekim952522000 &raquo;</TD></TR><TR><TD CLASS="quote">What tabs would I need to trim?
Right now the car is at stock ride height.</TD></TR></TABLE>
the "Tabs" are the extra plastic material where the edge of the plastic bumper bolts onto the metal fender. If you take off the rear wheel and look under there, you can trim material from the inside edge with a Dremel tool to give you a little more tire clearance. The only material you have to keep is the bolt (obviously) and anything visible from the outside.
at stock height, you shouldn't have any rubbing issues
Old Aug 2, 2006 | 09:12 AM
darkspector2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HxClude &raquo;</TD></TR><TR><TD CLASS="quote">
at stock height, you shouldn't have any rubbing issues </TD></TR></TABLE>
Old Aug 2, 2006 | 12:56 PM
lYellowDragonl's Avatar
im running 235/45/17 in the front and they rub like crazy on turns :\ but i dont lose traction
Old Aug 2, 2006 | 01:20 PM
Default Re: (lYellowDragonl)
That is taller but what offset wheel are you running?
superiorx120
Dec 1, 2010 02:10 AM
LudeJdm
Mar 21, 2007 07:21 PM
ej2_sir
Sep 8, 2006 06:00 AM
viet_lude
Aug 28, 2006 02:00 PM
lakerschamp2000
Nov 28, 2005 03:33 PM
