Ok to by a used a/c compressor
Old Aug 1, 2006 | 07:59 PM
c1civic's Avatar
Default Ok to by a used a/c compressor
in my dd, a stock 97 civic ex, the compresspr locked up the other day at 116k. I want to keep ac, but a new compressor is 400+. A local shop says they have a couple that will fit. Is it ok to buy a used one and just recharge the system...or is there more i have to do. Please let me know
thanks
Old Aug 1, 2006 | 08:06 PM
Paxil4x4's Avatar
Default Re: Ok to by a used a/c compressor (c1civic)
Would you buy a used condom? Unless it is sealed on a running car run far away from used compressors
Old Aug 1, 2006 | 08:18 PM
c1civic's Avatar
damn its that big of a deal, so basically the options are spend all the money, or take it out?
Old Aug 1, 2006 | 08:32 PM
axiomjunglist's Avatar
Default Re: (c1civic)
No...don't waste your money on a new compressor. I bought one off ebay that works perfectly on my 92 hatch, taken from a 94 civic with 100k. Give the compressor a spin (twist the top where the pully goes). It should move effortlessly. If it's stiff or barely moves it's a dud. Blow some air in the holes to get any dirt out and use the correct oil, and you'll be fine. Don't forget to vacuum before recharging or it's a waste of time.
see the huge A/C thread for more info:
https://honda-tech.com/zero...age=1
seantobin5
Aug 24, 2012 05:50 AM
cocktails
Honda Civic (2001 - 2005)
Mar 24, 2011 02:35 AM
prime-R
Jul 3, 2010 04:42 AM
rarak69
Jun 8, 2006 01:14 PM
Spoon4door
10
Aug 17, 2004 11:25 AM
