auto to 5 speed
that mean i have bigger issues on my hands then,, it doesn't even turn over, the lights in the center of the dash go out and thats it,,
i did auto to manual and had same problem then forgot to set the neutral switch to park postion..... move your neutral switch up to park and move it till you can start car and take key out good luck
theres the box under the center piece where the shifter connected... i just left mine in and move piece to park... mines a 92... i left mine in cause like a theft protection i move to drive and car wont start
Now this is pretty easy, but then again i love electrical. But all you need to do is connect 5 wires total. One of the plugs that you disconnected from the auto shifter is a 14P plug. Cut the plug off. Your going to have a 2 thick blk wires and 1 blk/blu wire, Solder those 3 together. Those together lets your car think its in park and releases the key and starts your car. Important
Next there is a yel/red wire and a grn/blk wire. Doesnt matter what way they go they do the same. These are for your reverse lights. Connect some line to them and run it through the firewall to your reverse light switch. And your set.
Sadly i couldnt figure out the Cruise control but i believe because the car thinks its in park to get the key and start it wont allow you cruise control. But if you want to know your Cruise control wire its a pink wire.
https://honda-tech.com/zerothread?id=1337459
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Now this is pretty easy, but then again i love electrical. But all you need to do is connect 5 wires total. One of the plugs that you disconnected from the auto shifter is a 14P plug. Cut the plug off. Your going to have a 2 thick blk wires and 1 blk/blu wire, Solder those 3 together. Those together lets your car think its in park and releases the key and starts your car. Important
https://honda-tech.com/zerothread?id=1337459</TD></TR></TABLE>If you were to wire the first set of wires to a switch attached to the clutch pedal ie one that is normally closed when you pushed in the clutch the contact would close and act like a park switch. you would just have to figure out witch ones went to the autos park switch. this should allow you to figure out how to get the cruise to work
JokerX-1.6T
Jun 8, 2007 05:08 PM
Jmunk
19
Feb 25, 2006 12:42 PM
honda95civic
Audio / Security / Video
Dec 11, 2005 04:50 PM
