squeaking noise while braking
Old Aug 1, 2006 | 05:38 PM
paxorion's Avatar
Default squeaking noise while braking
i just noticed today, that my 04 accord lx sedan (51k miles w/ the original brakes when i bought my car new) has a very faint squeaking sound coming from the front right whenever i am braking and coming to a complete stop when my speed drops under ~10-15mph. i don't notice any difference in the ability to brake, or a change in the way my car stops.
anyone have any clues as to what might be happening?
Old Aug 1, 2006 | 06:03 PM
YeuEmMaiMai's Avatar
Default Re: squeaking noise while braking (paxorion)
inspect your brakes and make sure that they are not worn down. If they are fine, but some anti squeak on the shims
Old Aug 1, 2006 | 06:48 PM
hondadude's Avatar
The newer honda brake pads are a really hard material[compared to early 90's] and rotor glazing is a problem, look at the rotors and if you can see yourself in the rotor it's time to have them resurfaced, as a test you can scuff them up with some 60 grit sand paper to see if the noise goes away for a day or two. Also when the pads wear down pretty far the pad material can't dissapate the heat and the pad will get cracked and cooked. I hate that high pitched sound, puts my teeth on edge and makes me want to wear earplugs. There is a service bulletin about this problem.
Old Aug 4, 2006 | 06:12 AM
paxorion's Avatar
what material are the brakes that 04 accords are equipped with? i was told when i called a merchant's tire and auto center that they used ceramic brakes?
Old Aug 4, 2006 | 09:59 AM
civicboisi's Avatar
It should be a Ceramic Pad.
There are Organics and Semi-Metallic that works just as good, but you get a harder pad as someone stated above and more brake dust with these two.
Old Aug 4, 2006 | 06:30 PM
standbackimapro's Avatar
just, get some new brake pads
Put the grease on the shims
if thats not it, Try replacing the Slider boots
canooten
11
Sep 12, 2014 09:39 AM
dbbyleo
Aug 30, 2008 01:06 PM
Landshark68
Apr 20, 2007 10:01 AM
M4
Jun 9, 2006 10:13 AM
Acuracy
Sep 2, 2002 03:57 AM
