which part is the main relay
Old Aug 1, 2006 | 10:22 AM
george34's Avatar
Default which part is the main relay
Is #17 the main relay?
http://www.hondaautomotivepart...-HORN
Old Aug 1, 2006 | 10:27 AM
crx_88_si's Avatar
yes. Another view for your reference.
Old Aug 1, 2006 | 10:43 AM
george34's Avatar
Default Re: (crx_88_si)
Thanks for the reply and the instructions. I have seen a main relay but I could not tell by there picture and it just said relay. Is that a good price for the main relay? That website normally has about the best prices.
Old Aug 1, 2006 | 10:48 AM
PnkRokCountryboy's Avatar
Default Re: (george34)
ya, thats a good price. mine cost somewhere around $90 from the honduh dealer.
good luck.
Old Aug 1, 2006 | 10:49 AM
Tyson's Avatar
whats wrong with your main relay? have you tried to repair the solder weld? usually its just a cracked solder dot that just needs to be heated up and rewelded.
other than that, they are plentiful in the junkyard.
but $45 for a brand new one, i guess youre paying for convenience and guarantee it will work. so if youre time is valuable, then yeah, its the cheapest youll find.
Old Aug 1, 2006 | 10:51 AM
george34's Avatar
Default Re: (PnkRokCountryboy)
Could the main relay cause my car to sputter for the first mile I drive my car? I plan on buying a main relay either way because they seem to be a common thing to go out so it won't be bad thing to have either way. I'm also buying a new fuel filter to see if it helps any.
Old Aug 1, 2006 | 10:54 AM
Tyson's Avatar
no, doesnt sound like a main relay issue. could be, but not typically whats wrong with main relays. usually it just wont let the car start on hot days or will shut the car down because it stops supplying the fuel pump power.
http://techauto.tripod.com/mainrelay.htm
Old Aug 1, 2006 | 11:08 AM
george34's Avatar
Default Re: (Tyson)
I don't have a desodering pump and my sodering skills suck.haha After reading that link my does not like to start sometimes when it is hot out if I don't let the fuel pump prime and then try to start it.
Old Aug 1, 2006 | 11:21 AM
Tyson's Avatar
i dunno. my car doesnt like to start quickly either without being primed, but thats just because theres a small leak around one of my injectors that loses fuel pressure over lng periods of time, especially overnight or at the end of the day of work.
its not symptomatic of your main relay in my opinion.
Old Sep 27, 2006 | 02:50 PM
integramic's Avatar
Can you tell me what it says under the prostreet symbol....Thanks.....that is where my problem is on a 86 crx si...
Old Sep 27, 2006 | 02:56 PM
Pee Wee's Avatar
Default Re: (integramic)
whatever you do dont buy a new one. i never soldered **** in my life before and i was able to fix mine on the first try.
Old Sep 28, 2006 | 11:34 AM
integramic's Avatar
Any idea on how much volage I should get on step 7 above......I getting .5
big.turbo.daddy
May 27, 2015 09:14 PM
scorpiontank
Jul 20, 2007 01:21 PM
90civicturboed
Jul 29, 2005 08:47 PM
