will a SH tranny with a base model?
base h22 = regular h22 block
Sh h22 = different block
I believe that not only will it not work but it won't even mount up on engine.
You would be better off getting a jdm tranny with an lsd.
The SH tranny will bolt up, but I'm not sure if it'll even work. I know for a fact that a Base tranny will bolt up to an SH block and work, cause I did this with my first Prelude and it worked just fine, just have to get an adapter plate for the axle in place of the ATTS system. I don't see why it wouldn't work the other way around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PiNoY_BB6 »</TD></TR><TR><TD CLASS="quote">No...
the SH tranny has the ATTS...</TD></TR></TABLE>
The ATTS system is seperate from the tranny. It actually sits right behind the oil pan drain bolt
How do I make the plate or where can I get it?
oem_certified_accord
Aug 22, 2007 09:23 PM
