Calipers for '90-'91 EX Sedan Uprights
Old Aug 1, 2006 | 08:26 AM
djphonics's Avatar
Default Calipers for '90-'91 EX Sedan Uprights
Soooo I did some searching and I have got a decent idea of what I need, but I was wondering if someone has a list of all the cars with calipers that will fit (without machining the caliper mount) the '90-'91 EX Sedan uprights.
I've already got the uprights and I want to put them on my '88 CRX Si with the 11" prelude rotors, but I need to get some calipers. As far as I know, I can use these without mods to the caliper bracket:
-Accord Wagon calipers
-NSX calipers ($$)
I heard these work as well (??):
-Acura CL calipers (not sure what years)
Thanks ya'll.
Old Aug 1, 2006 | 08:30 AM
CRX Toad's Avatar
Default Re: Calipers for '90-'91 EX Sedan Uprights (djphonics)
You can use ITR, Legend, Accord Wagon, NSX
You will also need to mill the bracket 2.5-3.0mm to make it all fit but that is easy.
Old Aug 1, 2006 | 08:53 AM
djphonics's Avatar
Default Re: Calipers for '90-'91 EX Sedan Uprights (CRX Toad)
Well i've got a connection at a machine shop, so i suppose i will go ahead and get those mounts milled down.
Old Aug 1, 2006 | 11:55 AM
CRX Toad's Avatar
okay but make sure you do it on the proper side of the caliper bracket. Otherwise you will screw your caliper bracket up and it will not work.
You need to mill the part of the bracket that touches the spindle.
And they will look like this in a 15" rim.
Also I would HIGHLY recomend getting a 90-93 Integra NON-ABS booster and MC.
kbud
Jun 17, 2016 10:49 AM
jfoster
Suspension & Brakes
Mar 29, 2009 07:58 PM
trytomake
Dec 16, 2008 06:32 AM
DA9Rood
Aug 26, 2006 02:35 AM
b16supertuner
Acura TL, RL & ZDX
Mar 10, 2006 05:33 AM
