sterring wheel shakes at high speed
Old Aug 1, 2006 | 03:27 AM
sikluder's Avatar
Default sterring wheel shakes at high speed
hey i have this problem, my steering wheel shakes at high speed at about 70km/hr+ and shake more when i hit the brakes. What do u guys think is the problem with it. Is it the braking system or my power steering belt gone bad?? Plz help me.
But i still drive at high speed with this problem , but sometimes scares the **** out of me .
Old Aug 1, 2006 | 03:41 AM
ECX's Avatar
ECX
* B A N N E D *
Default Re: sterring wheel shakes at high speed (sikluder)
my first guess would either be brakes or alignment, or atleast those are the two fairly easiest things to check and do...
Old Aug 1, 2006 | 04:06 AM
sikluder's Avatar
Default Re: sterring wheel shakes at high speed (ECX)
well i did a search on it and they point out that my rotors may be warped. Can anything else cause this shaking.
Old Aug 1, 2006 | 04:30 AM
bluedlude's Avatar
your tires need to be balanced my friend......
Old Aug 1, 2006 | 05:33 AM
maks's Avatar
Default Re: sterring wheel shakes at high speed (bluedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">your tires need to be balanced my friend......</TD></TR></TABLE>
That's the very first thing I would do. After that, check brakes, if the problem persists, there are more complicated things, but those two are usually the cause.
Old Aug 1, 2006 | 10:11 AM
daoshao's Avatar
Default Re: sterring wheel shakes at high speed (maks)
check tire pressure, wear, and get them balanced. Had this happen on my acura legend. It only shakes over 60mph.
Old Aug 1, 2006 | 11:08 AM
VtecFreePrelude's Avatar
mine does the same thing but only when i hit the brakes. stops shaking when i am going slower and i just replaced my rotors and pads so i don't know what it is
Old Aug 1, 2006 | 11:57 AM
thegeorge613's Avatar
I have a similar problem. The rear of the car shakes whenever I'm between 30-40mph. The guy who I bought my car from replaced one rear tire and I guess he didn't align or balance.
Old Aug 1, 2006 | 08:41 PM
BeE_B4's Avatar
It'S THe AlINgMeNt...weLl YeAh ThatS wHAt HaPPEn TO MIne THaTs WHy.....
Old Aug 1, 2006 | 09:07 PM
LudeBehavi0r's Avatar
Please stop with the caps and what not, your gonna get docked points quick doin that.
As far as his problem, i'd assume its brakes more than the alignment b/c he says it gets worse when he hits the brakes. I'd go check out your front rotors and pads asap.
Old Aug 2, 2006 | 12:15 AM
Layziejoe775's Avatar
Default Re: (Ludebehavior85)
yea...then check the alignment....and wheels
Old Aug 2, 2006 | 02:56 AM
madcatz's Avatar
Im going with alignment.
it happens when he isnt on the brakes.....that or your hub assembly is shimmed and your going to have to replace that and your wheel bearings. I just got done dealing with that......but that is a VERY Rare occurance, so check that off the list of what it shouldnt be
Old Aug 2, 2006 | 04:10 AM
97Preludeguy's Avatar
Default Re: (madcatz)
Warped rotors or trashed wheel bearings, I can almost guarantee it
Old Aug 2, 2006 | 05:55 AM
ECX's Avatar
ECX
* B A N N E D *
Default Re: (97Preludeguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Preludeguy &raquo;</TD></TR><TR><TD CLASS="quote">Warped rotors or trashed wheel bearings, I can almost guarantee it </TD></TR></TABLE>
d3vilishSi's Avatar
I had the exact same problem when I bought my lude...after balance and alignment it stopped.
Old Aug 2, 2006 | 06:10 AM
Lewdin' Incognito's Avatar
Default Re: (d3vilishSi)
cheapest to not:
tire pressure
lug nuts loose
wheel balance
wheel alignment
warped rotors
stabilizer
wheel bearing
axle/cv joint?
Most of what everyone else said, but these are what you should probably check.
Old Aug 2, 2006 | 08:22 AM
fzr's Avatar
fzr
I've been through three sets of OEM front rotors in the two years I've had my lude, they just keep warping, I get them replaced on warranty each time. Next time though I'm getting some different parts as it's getting boring.
I have another slight wobble due to a buckled wheel (buying used wheels on eBay = ). My poor lude needs some love.
Old Aug 5, 2006 | 04:28 PM
nailbender42's Avatar
i'd be willing to bet on tires out of balance. i'd try that first because that's the cheapest and if you have any wear at all on them it wont hurt to have them rebalanced anyway
prelude_93vtec
May 16, 2007 02:40 PM
civicb16eg
May 15, 2006 10:33 PM
93teggsr
Mar 6, 2006 08:00 AM
upwind
May 12, 2005 06:10 PM
chrisnova
Aug 10, 2004 01:41 PM
