Can I use these injectors when converting DPFI to MPFI?
Old Jul 31, 2006 | 10:47 PM
dohdoh420's Avatar
Default Can I use these injectors when converting DPFI to MPFI?
Can I use obd1 or obd2 fuel injectors when converting to MPFI if I have the correct wire plugs to go with the injectors and just wire them? do they require different resistor boxes? can an obd0 PM6 ECU run them?
Old Apr 13, 2007 | 02:28 PM
ys1civicsi's Avatar
Default Re: Can I use these injectors when converting DPFI to MPFI? (dohdoh420)
nope
Old Apr 13, 2007 | 02:31 PM
Furyof4's Avatar
Default Re: Can I use these injectors when converting DPFI to MPFI? (ys1civicsi)
Yes you can use them, just wire them up with out a resistor box.
Old Apr 13, 2007 | 06:42 PM
boostedblkef's Avatar
Default Re: Can I use these injectors when converting DPFI to MPFI? (Furyof4)
obd1 and 2 uses saturated injectors( no resstor box ) non obd or obd 0 uses peak and hold ( resistor box) so if your using 0bd1 or2 dont wire in a resistor
Old Apr 14, 2007 | 07:03 PM
BlueCrxNC's Avatar
Default Re: Can I use these injectors when converting DPFI to MPFI? (boostedblkef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedblkef &raquo;</TD></TR><TR><TD CLASS="quote">obd1 and 2 uses saturated injectors( no resstor box ) non obd or obd 0 uses peak and hold ( resistor box) so if your using 0bd1 or2 dont wire in a resistor </TD></TR></TABLE>
You can use either kind (saturated or peak and hold) because the ECU doesn't do anything to the injectors other than ground their 'signal' wire. There's not really a good reason to use saturated unless that's the only kind you can get your hands on. Peak and Hold are about .5 ms faster in response and thus perform better. Well, since you're doing a MPFI conversion, Saturated would mean not having to add in a resistor box at all... up to you bud.
jdmdikk
May 8, 2009 06:50 PM
nitewolf
Mar 25, 2008 07:04 PM
killa rex
Jan 25, 2006 02:54 AM
crex23
Dec 5, 2005 02:34 PM
e jay one
Aug 6, 2005 02:48 PM
