code 4, 6, 7, & 10 wtf?!?!?!
Old Jul 31, 2006 | 08:44 PM
90efSI's Avatar
Default code 4, 6, 7, & 10 wtf?!?!?!
all of the sudden i start thowing these codes?!?!? can someone help????
-thanks
Old Jul 31, 2006 | 08:47 PM
STDClayton's Avatar
Default Re: code 4, 6, 7, & 10 wtf?!?!?! (90efSI)
distributor going bad?
Old Jul 31, 2006 | 08:53 PM
90efSI's Avatar
everything has been working fine... i drove it all around today and it ran fine. i started wipeing down the engine bay a lil and the went to start it and it starts throwing all these codes
---HELP---
Old Jul 31, 2006 | 09:00 PM
Tippyman's Avatar
I tried cranking the car with one of the ECU plugs undone one time. (woops!) Once I figured out why it wouldn't start, it thrrew codes, I guess cause the wires weren't connected.
Take off you negative battery cable for like 30 seconds and put it back. If all your radio presets are gone, you've reset your ECU and the codes will be gone if it were a one time thing.
Old Jul 31, 2006 | 09:02 PM
nelsmar's Avatar
did you accidently make the pasanger side round plug loose? make sure all plugs are right, put car onto ON position. and pull the negative off the battery count to 60. and put it back on. should be okay. another way i think i s... on position remove hazard plug for 60 seconds(60 to be safe).
give us a heads up if this works
Old Jul 31, 2006 | 09:10 PM
90efSI's Avatar
k i un did the battery and my presets on my radio went away but the ecu didnt re-set... it was still throwing the same codes before i even started the car....
also what is the passenger side round plug???
-thanks
Old Aug 1, 2006 | 10:34 AM
crx_88_si's Avatar
see the main fuse box on the bottom of the pic, that big round white plug is the one they're talking about
Old Aug 1, 2006 | 08:50 PM
90efSI's Avatar
just checked it and it doesnt seem loose to me....
for somereason im also idleing a 10 vac...
Old Aug 1, 2006 | 10:41 PM
RCautoworks's Avatar
Default Re: (90efSI)
An alternator going bad will cause weird things
Old Aug 2, 2006 | 12:15 PM
90efSI's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">see the main fuse box on the bottom of the pic, that big round white plug is the one they're talking about
your a ******* geniuse!!!! that was it!!! expletive i almost sold my car for dirt cheap b/c i didnt want to deal with wiring prolems!@!!!! lol i feel like a dumb ***!!!!
THANKS GUYS!!!
jerry52
Aug 18, 2009 01:42 PM
beat
Aug 8, 2009 12:46 AM
gratefulrog
Oct 18, 2005 03:35 PM
oi-punx
Dec 14, 2002 10:00 AM
