TW: 98 b18b...long block
TESTING WATERS/FT..thinking bout selling my 98 b18b..recently rebuilt at 20,xxx miles due to bent rod...crank was checked out perfect at machine shop...block fresh honed...new rings, new main, rod, and thrust bearings, new oil pump, water pump, timing belt, new head gasket as well as IM gasket, has arp head studs,new valve cover gasket and gourments.also has new oil pan gasket..motor is freshly rebuilt...has ZERO miles on it as it is still on the engine stand...
MAKE reasonable offer...no low ballers...or will trade for sleeved block with crank and mains....
ludesleep
May 12, 2003 10:13 PM
