88 crx si transmission hell!
Old Jul 31, 2006 | 06:46 PM
white90crxhf's Avatar
Default 88 crx si transmission hell!
i cannot shift my transmission into 5th gear, i get 1,2,3,4 & reverse!
i had a bad 5th syncro ring, it is "stuck" on the 5th gear so i replaced it with one that works from my old hf tranny, when i shift into reverse, the 5th shift fork comes down over the 5th gear & syncro ring... is this correct? any ideas what is effed up? the shift fork itself?
Old Jul 31, 2006 | 07:28 PM
onepoint6i's Avatar
Default Re: 88 crx si transmission hell! (white90crxhf)
subscribing, cause i have an Si trans laying in my patio with the same problem..
i've seen synchros and shift forks look perfectly normal, yet still wont go into gear.... bad assembly :shrugs:
Old Jul 31, 2006 | 07:53 PM
Default Re: 88 crx si transmission hell! (onepoint6i)
should i try swapping the 5th shift fork from my hf tranny? i've been rebuilding this transmission for the past month...haha...
Old Jul 31, 2006 | 10:09 PM
removed the non-sense.
Modified by white90crxhf at 11:09 PM 8/1/2006
sdr85
Dec 6, 2007 11:54 PM
crj_lll
Jul 25, 2005 09:20 PM
sterjess
Jun 22, 2005 07:37 PM
spiderseth
Nov 10, 2004 04:17 PM
snatch
Jul 1, 2004 07:01 PM
