ek9 pwr folding mirrors. (help)
Old Jul 31, 2006 | 04:33 PM
BillyBalls's Avatar
Default ek9 pwr folding mirrors. (help)
hi. i am trying to install a set of ek9 ctr power folding mirrors. they came from a 2000 model year. installing into 2000 civic si. i was wondering if anyone knows where i can get a wiring diagram for these mirrors. thanks.
Old Jul 31, 2006 | 04:52 PM
orientalgunz_00's Avatar
here's what i used...hope it works...
Old Jul 31, 2006 | 05:16 PM
BillyBalls's Avatar
Default Re: (orientalgunz_00)
thanks for the reply! the only thing i am missing is the relay. the seller told me that these didnt need a relay because they were oem and had one built into the switch already.
Old Jul 31, 2006 | 05:25 PM
melsers's Avatar
Default Re: (BillyBalls)
bullcrap the relay is separate
Old Aug 1, 2006 | 07:03 AM
BillyBalls's Avatar
I dont know if this matters but i have one harness with five wires, and the other harness has seven. i noticed that my factory harness is the same way. 3 on the left and 5 on the right. in the diagram it only shows five for each mirror. what are the other two wires for? also can i use any old relay or do i need an oem one. i noticed that the oem relays have a plug in port. any ideas on where to find that harness or should i just shop around on ebay?
Old Aug 1, 2006 | 08:23 AM
melsers's Avatar
you need the oem one.. try passwordjdm, jdmshit, icb, etc
Old Aug 2, 2006 | 06:05 PM
yea, i'm w/ melsers on this one...just get the oem one to lessen your headaches...i experimented w/ radioshack relays and couldn't get that **** to work...oem relay was plug and play...my mirrors only had five wires coming out to the harnesses...i don't know about seven wires....
Old Aug 2, 2006 | 06:18 PM
melsers's Avatar
mine had 5 wires also, 3 are for the mirror adjustment, 2 are for folding, and i think some civics had optional heated mirrors, which is what i'm guessing the extra wires are for
Old Aug 3, 2006 | 12:35 PM
BillyBalls's Avatar
Default Re: ek9 pwr folding mirrors. (BillyBalls)
i wired them into the factory wires and have the mirror adjustment working. i know i need the relay but i have seen different ones. will any of these work. also i noticed that i need a harness to plug into the relay as well. thanks alot!
Old Aug 3, 2006 | 06:11 PM
melsers's Avatar
you need this:
http://passwordjdm.com/product...D=254
comes with the pigtail harness
Old Aug 3, 2006 | 06:17 PM
FalkenSiR's Avatar
Default Re: ek9 pwr folding mirrors. (melsers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melsers &raquo;</TD></TR><TR><TD CLASS="quote">you need this:
comes with the pigtail harness </TD></TR></TABLE>
a lot
but worth it
Old Aug 3, 2006 | 06:38 PM
melsers's Avatar
Default Re: ek9 pwr folding mirrors. (fast95eg8)
if you're lucky you might find one for cheap on eGay
Old Aug 9, 2006 | 05:55 PM
BillyBalls's Avatar
thanks guys!
crx_si-r
Northern California (Sales)
May 24, 2009 11:05 AM
exotik4doorcivic
May 15, 2009 11:54 AM
crx_si-r
37
Mar 29, 2009 03:45 PM
PrOjEct CTR
Jul 27, 2003 10:25 PM
