car wont start
Old Jul 31, 2006 | 04:26 PM
slowcrxsib16's Avatar
Default car wont start
put fuel pump in my car, and well now the **** wont start, the pump is priming and pumping, but i dont think that has anything to do with it, i changed out the main relay and there are no blown fuses. I turn the key on and CLICK! thats it, i put a new battery in and had the starter checked and it checked good, i really dont know what the hell it could be. I checked all the fuses under the hood and they were fine. Im thinking it could be my ignition switch, but i dont know if it would be the lock cylinder or the switch in side. like i turn the key on and all the lights on the dash come up and the pump comes on, but i go to start it, then nothing. the car doesnt even attempt to fire. I dont know what the hell it could be, im really just getting fed up if you know what i mean, im trying to get this **** done.
Old Jul 31, 2006 | 05:45 PM
CLE's Avatar
CLE
Turn key to on position, use some wire and jump the starter. If the car starts your ignition is most likely bad.
Old Jul 31, 2006 | 06:04 PM
Kevin B's Avatar
Default Re: car wont start (slowcrxsib16)
Had an intermittant problem like yours. Could be your ignition switch. Check the contacts for the switch. It is easy to take apart. Two screws that will separate the switch from the key part and then there are tabs that hold the white cover in place. Take that off and check the contacts, mine were dirty. Cleaned them off and problem went away. Make sure you disconnect the battery first.
Old Jul 31, 2006 | 07:00 PM
zccr-xsi's Avatar
Default Re: car wont start (Kevin B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevin B &raquo;</TD></TR><TR><TD CLASS="quote">Had an intermittant problem like yours. Could be your ignition switch. Check the contacts for the switch. It is easy to take apart. Two screws that will separate the switch from the key part and then there are tabs that hold the white cover in place. Take that off and check the contacts, mine were dirty. Cleaned them off and problem went away. Make sure you disconnect the battery first.</TD></TR></TABLE>
x2
u can take some sandpaper to the contact points to make them shiny again then put tiny amount of elc. grease on them then put it back together.i had this same prob too i found out what it was one tumbler and ingtion harness later.
89LSED
Sep 24, 2010 05:02 PM
taboo948
May 19, 2008 07:26 AM
Herc130
Jul 27, 2007 07:29 PM
rodvang
23
Nov 5, 2005 05:57 PM
UNDER PRESSURE
Jun 21, 2004 08:47 AM
