D16Z6 Tranny Rebuild ....
Old Jul 31, 2006 | 03:46 PM
Eran's Avatar
HT White Ops
Default D16Z6 Tranny Rebuild ....
I cannot for the life of me get the c-clip off the back so the main shaft and countershaft will drop ....
Help
Old Jul 31, 2006 | 03:52 PM
FIGARILA's Avatar
Default Re: D16Z6 Tranny Rebuild .... (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">I cannot for the life of me get the c-clip off the back so the main shaft and countershaft will drop ....
Help </TD></TR></TABLE>...what are you using to remove the c-clip? are you adding pressure to the case? i use a special c-clip opening tool ($10)
Old Jul 31, 2006 | 04:44 PM
Eran's Avatar
HT White Ops
define "adding pressure to the case"
Old Jul 31, 2006 | 05:01 PM
thehatchninja's Avatar
that sucks.....
-take out the tranny fill plug
-put a 10mm socket in there.
-start screwing the plug back in.
that will put a little bit of lifting force against the clip, then spread the C-clip.
You have to get the right amount of pressure. Good luck
Old Jul 31, 2006 | 05:14 PM
FIGARILA's Avatar
Default Re: (thehatchninja)
^^^^ thats a good idea^^^^^
Old Jul 31, 2006 | 05:25 PM
Default Re: (Heron of Alexandria)
that's Bense's trick....which he might have gotten from Bone.
Old Jul 31, 2006 | 06:30 PM
Eran's Avatar
HT White Ops
Well, I went out and picked up a c-clip separator, and I had my girlfriend pry the case with a crowbar, and POP.
Thanks for the help .... now the fun part ..... cleaning this bitch up and replacing the ISB.
Old Jul 31, 2006 | 08:13 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">that's Bense's trick....which he might have gotten from Bone. </TD></TR></TABLE>
i actually got it from evs-one
Old Jul 31, 2006 | 09:42 PM
Mista Bone's Avatar
D Tranny Guru
92-95 trannys have pry points, a 17mm and 19mm open end wrench fors perfect.......
Old Aug 1, 2006 | 02:21 PM
Eran's Avatar
HT White Ops
My ISB is stuck ..... the plastic casing inside that holds the ***** was completely shredded, so the ***** and inner ring just fell out. I can't get the outer ring to come loose .... someone help?
Old Aug 1, 2006 | 04:00 PM
Eran's Avatar
HT White Ops
help
Old Aug 1, 2006 | 04:07 PM
do you have a puler?
Old Aug 1, 2006 | 05:09 PM
FIGARILA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">do you have a puler?</TD></TR></TABLE>...yeah your going to need a puller, my craftsman cost me like $20. Make sure the arms will fit
Old Aug 2, 2006 | 02:15 AM
Mista Bone's Avatar
D Tranny Guru
put the ***** back in and space the out so the puller can work.........
if not your gonna have to cut it out with a dremel......
mikeycivic01
Jan 1, 2007 03:47 PM
B16 IIgen
Oct 26, 2006 04:34 PM
sk3ch
Sep 14, 2006 06:25 PM
ATS*EK24
May 9, 2006 09:30 AM
DC_RaceR
Mar 7, 2006 04:18 PM
