D16Z6 Tranny Rebuild ....
Re: D16Z6 Tranny Rebuild .... (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">I cannot for the life of me get the c-clip off the back so the main shaft and countershaft will drop ....
Help </TD></TR></TABLE>...what are you using to remove the c-clip? are you adding pressure to the case? i use a special c-clip opening tool ($10)
that sucks.....
-take out the tranny fill plug
-put a 10mm socket in there.
-start screwing the plug back in.
that will put a little bit of lifting force against the clip, then spread the C-clip.
You have to get the right amount of pressure. Good luck
HT White Ops
Well, I went out and picked up a c-clip separator, and I had my girlfriend pry the case with a crowbar, and POP.
Thanks for the help .... now the fun part ..... cleaning this bitch up and replacing the ISB.
Go Tigers!
Re: (thehatchninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja »</TD></TR><TR><TD CLASS="quote">that's Bense's trick....which he might have gotten from Bone. </TD></TR></TABLE>
i actually got it from evs-one
HT White Ops
My ISB is stuck ..... the plastic casing inside that holds the ***** was completely shredded, so the ***** and inner ring just fell out. I can't get the outer ring to come loose .... someone help?
Re: (thehatchninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja »</TD></TR><TR><TD CLASS="quote">do you have a puler?</TD></TR></TABLE>...yeah your going to need a puller, my craftsman cost me like $20. Make sure the arms will fit
D Tranny Guru
Re: (Heron of Alexandria)
put the ***** back in and space the out so the puller can work.........
if not your gonna have to cut it out with a dremel......
mikeycivic01
01-01-2007 03:47 PM
