Suspension & Brakes Theory, alignment, spring rates....
ek struts on eg?
Old Jul 31, 2006 | 01:25 PM
Richie B's Avatar
Default ek struts on eg?
he i have some ek springs and struts and i was wondering if the rear would fit on an eg
and what modification would it take to get it to work
tyia
-richie
Old Jul 31, 2006 | 05:33 PM
h22nr's Avatar
Default Re: ek struts on eg? (skatebart)
they should work.my boy put on a set of flexes off a em1 on his ej1
Old Jul 31, 2006 | 06:17 PM
Voyage34's Avatar
Default Re: ek struts on eg? (h22nr)
it will fit
if
you modify the bushing in the lower control arm. the EG bushing is wider than the one in the ek, so you will need to grind/shave off enough for the fork to fit over.
but then should you want to go back to eg shocks you would ideally need to replace the bushing. if you have them and are set on doing then then that will work, but otherwise, try to stick to the proper parts.
Old Jul 31, 2006 | 07:40 PM
Richie B's Avatar
Default Re: ek struts on eg? (Voyage34)
thank you
pleej
Suspension & Brakes
Feb 12, 2010 08:27 AM
ekb16a
Oct 29, 2009 01:52 PM
vizsual00
24
May 26, 2004 10:09 PM
