srs light
my trip meter isn't working, can that cause my srs light to be on?? i try resetting the srs light a few times but something is still causing the srs light to be on...
car: 96 integra ls
car: 96 integra ls
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan »</TD></TR><TR><TD CLASS="quote">Loose wire? Deployed airbag?
Your odometer isn't working? Maybe loose wires or a bad cluster? Try the fuses too
^ yup, also have installed an aftermarket steering wheel without SRS/ airbag...
</TD></TR></TABLE>^ yup, also have installed an aftermarket steering wheel without SRS/ airbag...
everything on my Cluster seems to work, except the Trip Meter.....(odometer works, etc...)
stock steering wheel....
fuse looks ok.... i don't know which wires should i check to see its loose or not....
