brake indicator light stays on....
Old Jul 31, 2006 | 11:48 AM
go2sleep's Avatar
Default brake indicator light stays on....
after trying to reset my srs light with no success, my brake indicator light now lights up. it lights up and stays on only when im in first gear and past 3k rpm. could this be related to me try to reset my srs light?
i'll have to check the brake fluid level and pull off the battery terminal to see if those will help.
Old Jul 31, 2006 | 02:33 PM
JSPECSIR's Avatar
Default Re: brake indicator light stays on.... (go2sleep)
the only thing that cuts that light on is the switch on the e-brake lever, and the switch on the float in your brake fluid resivoir. unless you have abs then i dont know what to tell you. so check that fluid, and make sure the ebrake is down.
Old Jul 31, 2006 | 08:17 PM
go2sleep's Avatar
Default Re: brake indicator light stays on.... (JSPECSIR)
i was low on fluid. added some more and the light is gone. now i need to figure out where it's leaking from....
Old Jul 31, 2006 | 09:18 PM
SHG_Beans's Avatar
If you've got rear drums check wheel cylinders first. Thats what i've usually seen go bad and leak before anything else.
MaWeiTao
Aug 8, 2010 12:49 PM
lampshadej1
Nov 29, 2009 07:34 PM
91H4hatch
Feb 17, 2007 07:15 AM
mmmtrbolude93
Aug 8, 2006 04:30 PM
intech
Nov 17, 2005 02:44 PM
