Honda S2000 Honda S2000
Anyone running 17x10s in the rear without modifying fenders?
Old Jul 31, 2006 | 10:30 AM
19sec beast's Avatar
Default Anyone running 17x10s in the rear without modifying fenders?
If so, what offset are you running? What size tires? Any rubbing issues?
I want something that will line up with the stock fenders without having to roll them or flare them out or require a widebody kit.
Going to upgrade from Work Emotion CR wheels which are 17x8 (f), and 17x9 (r).
Any suggestions? Pictures would be nice also.
Old Jul 31, 2006 | 11:28 AM
PNB's Avatar
PNB
GatorNATION
Default Re: Anyone running 17x10s in the rear without modifying fenders? (19sec beast)
Check the offset/wheel size guide on S2ki. It has answers for everything.
If that doesn't work, find Riley on there. He knows everything about wheels
Old Jul 31, 2006 | 12:41 PM
Default Re: Anyone running 17x10s in the rear without modifying fenders? (PNB)
Heh, ok.
Old Jul 31, 2006 | 06:44 PM
Francesco's Avatar
my friend is running 18x10 in the rear. he rolled his rears and is running alot of negative camber
Old Aug 1, 2006 | 07:00 AM
Default Re: Anyone running 17x10s in the rear without modifying fenders? (FR-MOB: Francesco)
Wanted to stick to 17s and didn't want to have to roll fenders at all.
Old Aug 1, 2006 | 10:30 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19sec beast &raquo;</TD></TR><TR><TD CLASS="quote">Wanted to stick to 17s and didn't want to have to roll fenders at all.</TD></TR></TABLE>
it have little to do with 17 or 18, unless you want to run smaller overall size(which is not recommended).
i don't see how you could get away with rolling the fender with 10 inch width rims.
Old Aug 1, 2006 | 10:46 AM
S2SLOW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Francesco &raquo;</TD></TR><TR><TD CLASS="quote">my friend is running 18x10 in the rear. he rolled his rears and is running alot of negative camber </TD></TR></TABLE>
Me 2 no problems just tire wear..
Old Aug 1, 2006 | 03:24 PM
- BSeRiouS -'s Avatar
Default Re: Anyone running 17x10s in the rear without modifying fenders? (FR-MOB: s2slow)
the work emotions you are looking at are im assuming the +44, +47 offset. These are moderately aggressive and you would have to run a stretched tire in order to achieve this without rubbing/ nor rolling fenders. a 215 up front, and a 225 in the rear. My friend is running a 235 on the rear of his 17x9 blitz 01's with a a +45 and barely clears but has occasional rubbage. You will lose contact patch in the rear because you WILL be running a smaller tire less than stock. a 225 stretch in the rear would be your best bet.
But they key is, are you willing to give up contact patch for looks? are you willing to run a smaller tire size thats way hella smaller than stock? thas all up to you. I for one love the stretch look, but many hate it. its'll all up to you
Old Aug 2, 2006 | 06:00 AM
Default Re: Anyone running 17x10s in the rear without modifying fenders? (OBSeRiouSo)
I'm not looking at purchasing any Work Emotions. They're already on the car. I don't want new wheels for looks, but for a better functioning car.
I'm going to be using a GT35/40R w/ a 50-75 shot of nitrous (~750rwhp) and wanted the extra 1" of contact patch for traction.
I may just keep the 17x9s in the back and use a 245 tire in the back.
Old Aug 2, 2006 | 06:46 AM
S2tripleO's Avatar
If you are running a 17 x 9 now, you should be able to go to at least a 255, possibly even a 265 rear tire. I am running 17 x 9 +65 with a 255 40 17 with no rubbing what soever.
Tyler
Old Aug 2, 2006 | 07:46 AM
Default Re: Anyone running 17x10s in the rear without modifying fenders? (S2tripleO)
I have some brand new, unmounted, 245/45/17, Azenis RT-615s sitting here. I'll give these a try and see how well they do. I may order some 255s for the next set.
Old Aug 2, 2006 | 09:31 AM
ITRbroham's Avatar
shit post warrior
Who makes 17x10 wheels?
19Sec Beast. Check PM.
Old Aug 2, 2006 | 09:33 AM
Default Re: Anyone running 17x10s in the rear without modifying fenders? (ITRbroham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRbroham &raquo;</TD></TR><TR><TD CLASS="quote">Who makes 17x10 wheels?</TD></TR></TABLE>
Work.
Old Aug 3, 2006 | 09:35 PM
Yosshaa's Avatar
10" rear = overklill for most s2k's
tires are costly as well.
Old Aug 4, 2006 | 08:53 AM
S2SLOW's Avatar
Default Re: (ambition)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ambition &raquo;</TD></TR><TR><TD CLASS="quote">10" rear = overklill for most s2k's
tires are costly as well.</TD></TR></TABLE>
Not true i work for Toyo, tires are cheap!!!
Old Aug 4, 2006 | 02:27 PM
ahbongkadah's Avatar
Default Re: (FR-MOB: s2slow)
people run 17x9 +50 F, and 17x10 +70 R CCW wheels without rubbing. Could run 275's too
Old Aug 4, 2006 | 04:06 PM
Default Re: (ahbongkadah)
Mmmmm.... 275s....
unevolved
Honda Civic (2001 - 2005)
Feb 3, 2009 07:59 PM
Casey
Acura TSX
16
Aug 14, 2008 04:06 PM
teamwasabi'sDC4
Mar 19, 2008 09:18 PM
showtymers619
Honda S2000
Sep 21, 2007 08:29 PM
Halo
10
Dec 7, 2004 12:30 PM
