valve cover help
Old Jul 31, 2006 | 09:37 AM
87shytwhip's Avatar
Default valve cover help
i broke threads on one of the bolt s that hold on the valve cover when i was trying to take it off to put on new seals.. it was extremly rusted and now i cant get it off.. im not sure what to do because now oil is leaking through slowly.. what can i do to get this problem resolved so i dont have a leak anymore..
Old Jul 31, 2006 | 09:39 AM
vlc92189's Avatar
the 4 outer bolts? or the 4 bolts that hold the spark plug cover on?
Old Jul 31, 2006 | 09:42 AM
87shytwhip's Avatar
Default Re: (vlc92189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlc92189 &raquo;</TD></TR><TR><TD CLASS="quote">the 4 outer bolts? or the 4 bolts that hold the spark plug cover on?</TD></TR></TABLE>
correct.. the spark plug cover ones
Old Jul 31, 2006 | 10:01 AM
87shytwhip's Avatar
Default Re: (87shytwhip)
i am tempted to drill it out but i dont know if that is the best idea
Old Jul 31, 2006 | 01:57 PM
d16vteceg's Avatar
DO NOT DO THAT. To save you a massive amount of time and trouble, go to the dealership, if it is a d-series you can go to honda, if it is a b-series go to either honda or acura, if you go to honda tell them it is from a b16(all b-series are interchangeable) and ask the parts guy for a new bolt. All you have to do is take your valve cover off, and the bolt is connected to the head by threads. You will need a deep socket, either 10mm or 12mm I can't remember. If it is the outer bolts, they are the small bolts, if it is the inner ones, they are the longer bolts. The parts guy will ask you this. The bolt is like 6 bucks for 1. I have done this twice. Once with the outer bolt, once with an inner bolt. It takes all of 5 minutes to replace. BTW. Your welcome in advance.
Old Jul 31, 2006 | 10:00 PM
87shytwhip's Avatar
Default Re: (B18chatch83)
thanks very much i will be doing this asap.. PLANT HONDA HERE I COME
Old Aug 1, 2006 | 05:24 PM
d16vteceg's Avatar
No problem
stuie08
Aug 14, 2007 12:01 AM
DarkDragon
May 25, 2005 07:34 PM
propulsion1
Oct 31, 2004 03:47 PM
bluesicruzzin
May 1, 2004 09:03 PM
Opie
Sep 29, 2003 12:41 PM
