Question on an EGR issue
Old Jul 31, 2006 | 09:32 AM
abuhun's Avatar
Default Question on an EGR issue
I have a 99 accord V6. I recently had the check engine light come up. The mechanic changed the EGR valve, but the engine light is still on. Another mechanic said the code is "EGR insufficient".
Any ideas on what else could be done?
Old Jul 31, 2006 | 09:55 AM
teamlegacy's Avatar
Default Re: Question on an EGR issue (abuhun)
Tell your mechanic to stop being shitty and throwing parts and diagnose the problem correctly.
edit: Which P code was it? There are a few with EGR Insufficient descriptions with them. I'll try and find the correct flow-chart if you give me the number.
Old Jul 31, 2006 | 04:48 PM
hondadude's Avatar
There is a big giant hairy SERVICE BULLETIN about this problem, the intake plenum needs to be removed and the port where the plenum meets the head is to be drilled out and have a steel tube inserted there.
Find a mechanic that has Alldata system or a brain.
8 year 80k mile warranty extension.
http://members.troublecodes.ne...5.gif
Old Jul 31, 2006 | 05:21 PM
Chiovnidca's Avatar
Default Re: Question on an EGR issue (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">
Is that for the egr system only?
Old Jul 31, 2006 | 05:46 PM
hondadude's Avatar
Default Re: Question on an EGR issue (Chiovnidca)
That particular service bulletin applies to EGR, there are other warranty extensions, some models have emission warranty extensions 14 years 150k miles.
http://members.troublecodes.ne...1.gif
kidcruze
Jul 18, 2008 01:45 PM
chieny
Dec 2, 2005 11:29 AM
djgalloway73
May 11, 2005 05:08 PM
97minitaco
Jul 5, 2004 06:34 PM
zeke mccune
Jun 2, 2004 08:09 PM
