Need electrical help
My car's turn signal's (all four) do not work. But when I turn on the hazards they flash. Also my gauge cluster does not work. I have changed gauge clusters to make sure that was not the problem also. I have checked all the fuses in the fuse block two or three times. Are there any other fuses or relays that would cause this?
supposedly there's a cluster fuse...I haven't opened mine yet I don't think, but from what I hear there's one in there, if the 4 ways all work but the directionals don't work, after I ruled out a fuse I would go 'n check the wiring to the directional switch...because obviously there's nothing wrong with the lights themselves if the 4-ways are working..
Get a fuse diagram too, 'cause you don't neccessarily have to be looking for a blown fuse..there might be a missing fuse...
Wow the topic of clusters being out is VERY popular. I'm sure a search would prove to work well. At any rate...there is a fuse in the fuse panel below the steering wheel. Read the fuse diagram inside the box. You want the fuse that controls the Interior Lights/Tail Lights. I beleive its a 7.5A or 10A. That should take care of it. If not... you have a short. Check all of your wires.
92hatch_cx-t
Jun 22, 2007 06:08 PM
jdmcd7_cali-luv
Jul 10, 2006 07:02 PM
GreenD16Y8
Aug 8, 2005 03:59 PM
