Expectations?? Reccomendations?
Old Jul 31, 2006 | 07:09 AM
solid gsr's Avatar
Default B20 Expectations?? Reccomendations?
What do you guys think I will get out of this engine setup? HP/Torque I know i will have to get it tuned, and what do you reccomend i should add to this if needed. I do have the crank girdle for the high rpm revving for the stock crank.
B20B/B16A Head
Golden Eagle Ls/Vtec Kit
AEM Cam Gears and Pulley's
Cat Stage 2 Camshafts
JDM PR3 Computer
Stock Ignition/Fuel Supply
Stock LS tranny
Also my crank pully has a chunk out of it any reccomendations on any other i buy?
Modified by solid gsr at 11:20 AM 7/31/2006
Old Aug 1, 2006 | 06:28 AM
solid gsr's Avatar
nothing??
Old Aug 1, 2006 | 07:00 AM
b18sihatch's Avatar
Default Re: B20 Expectations?? Reccomendations? (solid gsr)
unless you are getting the setup tune the cam gears are useless. but if tuned you can see a decent ammount of power gain
also with the camshafts, upgradind the springs,retainers,ect would go good and most camshafts recomend that. i would also upgrade the intake manifold if upgrading camshafts.
also ''pullies'' are you talking about a lightweight cranshaft pulley?
Old Aug 1, 2006 | 10:22 AM
solid gsr's Avatar
yes just a light crankshaft pulley, i have a b20 and a b16 intake manifold, to my knowledge the b16 has a larger inner diameter on the inside of the runner correct?? This engine will be dyno tuned at a really good shop.
a.ramirez82
Apr 22, 2011 10:44 AM
jdmboyef9
Northwest (Sales)
Oct 3, 2007 03:57 PM
ACrite3404
Dec 31, 2006 01:18 PM
ls_vtec_crx
11
Aug 23, 2004 04:35 PM
bluebomb
Apr 30, 2004 11:00 PM
