Chicago & Illinois: FS/FT WTB, August 2006
Old Jul 31, 2006 | 04:14 AM
Akiraboy's Avatar
Default Chicago & Illinois: FS/FT WTB, August 2006
Same as the last 2 months
Best offer, some light weight miata wheels
4x100 35-45 offset
11lbs approx each
pm me
FS: 195-70-14 tires, set of 4 dunlops
Wanted:
86-89 integra front lip
Old Jul 31, 2006 | 04:36 AM
d16rice's Avatar
Default Re: Chicago & Illinois: FS/FT WTB, August 2006 (Akiraboy)
Here's my little list
<FONT COLOR="33CC00"><FONT SIZE="3">Most prices are obo</FONT></FONT>
Everything is in excellent condition
Contact me if you need more info about something
<FONT COLOR="red">I prefer local pick-up, but will ship at buyers expense.</FONT>
<FONT COLOR="blue">For shipping expect add 50-150% of the selling price depending on how far you are.
Don't forget 3% Paypal fee. This is why I prefer local pick-up</FONT>
Complete MSD Ignition - $350
-MSD 6A box
-MSD S.S. blaster coil
-Custom aluminum mounting plate
-MSD 8.5mm Extreme spark plug wires
-MSD 8.5mm external coil wire
-MSD Extreme distributor cap
-D16Y distributor modified for external coil
most parts were used for less than 2K miles,
6a box and obviously distributor are a bit older.
OEM Radiator Fan - $30
Complete Engine head - $75
-Removed from a '97 DX, d16y7
Engine head w/valve cover - $65
-Removed from CRX when doing a mini me.
-Might be an a6 head, but I'm not sure
-I do NOT know the condition of this head
D16 Block guard - $55
-NEW KMS block guard, still in original packaging
OEM Cam gear - $25
-Removed from a '96 EX, d16y8
OEM Cam gear - $25
Free-flow cat converter - $65
1996-2000 EX resonator/test-pipe (might fit others)
with 02 sensor installed (can't be removed)
CRX exhaust manifold w/o2 sensor - $45
-Exhaust header (no down-pipe)
-Heatshield
-Single-wire O2 sensor
Automatic transmission - $100
-Removed from a '97 LX
-Works great, but makes a little wining noise (input shaft bearing might be going)
Starter for Auto-trans - $45
Alternator - $35
Underdrive crank pulley (NEW) - $50
-1992-1995 SOHC CIVIC
Driver side axle - $55
-Purchased from autozone 1-2K miles ago (used for a month)
Konig hub rings - $5 each
-Two NEW konig hub rings
-I purchased a complete set, but only needed two.
One rear LCA (not a pair) - $5
Cruise Control - $55
-Everything that’s under the hood
Cruis control bottons - $20
-Makes for a clean looking n2o swithc
Power steering pum + reservoir can - $55
Heater core - $100
Heater valve - $25
A/C compressor - $50
-Removed from a CRX
A/C condensor - $50
A/C switch - $30
A/C Core - $100
A/C Lines - $30
-Two lines, to and from core
A/C compressor bracket - $25
-Complete bracket with bolts and idler pulley
-needs new mount
Fuel filter painted <FONT COLOR="blue">BLUE</FONT> - $10
-Used for 1,9xx miles
Fuel line - $10
-From '97 LX (d16y7)
-The one that goes from fuel rail to fuel filter
Fuel injectors - $20
-From '97 DX (d16y7)
Fuel rail - $10
-1997 civic LX
Fuel rail - $15
-1997 civic DX
-Includes a bracket for remote fuel PSI regulator
Fuel PSI regulator (OEM) - $15
Fuel PSI regulator (OEM) - $20
-From '96 EX (d16Y8)
Intake Manifold (bare) - $20
Intake parts - $5 each
-I don't know what it is, came with an aftermarket air intake
K&N 2.75" conical, reusable air filter (used) - $35
Cool air intake - $35
-One piece CAI for a D16Y8 (might fit other civics)
-Inclued are bolts, brackets, hose fitings and a used filter.
Intake - $30
-Removed from 1997 LX (d16y7)
Intake - $35
-Removed from 1997 DX (d16y7)
Intake air temperature sensor - $25
Throttle cable - $5
EVAP sensor - $40
EVAP sensor - $40
Brake master cylinder - $30
P2E ECU - $40
-From '97 LX (d16y7) auto
P2E ECU - $40
-From '97 DX (d16y7) auto
Spark plug wires - $30
-Used 9.3mm APC
Spark plug wires - $55
-NEW 10.3mm OBX-R
Complete engine wire harness - $100
-Removed from a 1997 LX (d16y7)
Complete underdash (interior) wire harness - $50
Complete headlight wire harness - $50
Fuse box/fuses/realays (under the hood) - $40
Fuse box/fuses/realays (under the dash) - $40
Complete front dash - $150
-Type K, Light Grey
-Includes: Dashboard, Gauge bezel, Dim switch,
Cruise control switch, Wire harness, All vents,
Lower driver side panel, Power mirror switch, Fuse cover,
Lower middle panel, Power outlet, Glove box, Side panels (end-caps),
Steering column panel, "A" pillars, Kick panels, All brackets.
Center console - $80
Includes: Black center console trim, Two middle vents,
Window defrost and Hazard light switches, Coin tray, A/C controls,
Adapter plate for aftermarket radio, I can also include all wire plugs
Stock AM/FM radio w/rear speakers - $40
-I can also include stock rear speakers
Stock radio wire harness - $40
1.0frd Capacitor w/digital voltmeter - $65
Two 10” subwoofers w/ban pass box - $225
Rockford Fostgate
RFP3410
400W Max (200W RMS) 4ohm (each)
ProBend competition banpass R/T box
red neon in the box
Amplifier - $20
Sony 30W x 2 bridgeab amplifier
MX-3021 Mosfet
20-20KHz 0.04% T.H.D 4ohm
Three 6.5" infinity speaker grills - $10
Arm rest - $80
-Type K, Light Grey
-Includes: Complete arm rest, Cup holder,
Shifter console, Brackets
Arm rest eliminator - $30
-Dark Grey
DX gauge cluster - $30
Mini tachometer - $25
Rear view mirror (inside/center) - $15
Rear view mirrors (side/outside) - $50
-Non power side mirrors
-Will fit 96-00 coupe/hatchack
Dome Light - $10
Handles (roof) - $50
Front passenger seat - $50
Front seat uphostery - $50
-Removed from a 2000 civic Si
-Shows some wear on driver seat lower part, nothing ubnormal
-perfect if yours are riped/torn/burned...whatever
Front door handles - $20
-used, unpainted
Front upper grill - $35
-DIY GBP grill for 96-98 civic
Headlights - $100
-Factory headlights for 96-98 civic
Driver-side taillight - $30
Altezzas - $25
96-00 civic hatchback Altezzas
Taillights - $60
-Factory taillights for 96-98 hatchback
Cargo Cover - $100
-96-00 civic hatchback custom cargo cover
Inner trunk panel - $30
Rear license plate panel - $30
License plate lights - $20
Gas tank cover (GBP) - $15
Gas tank cover (chrome w/CF insert) - $50
Rear shelf - $30
-Type K interior, Light Grey
Trunk Vent - $5
Trunk Light - $10
Bumper Guards - $50
-These came on the car from O'hare Honda dealer
-Three are good, but one is torn where the car was hit
-Would need new double stick tape to reattach them.
Mud guards - $40
-Some usual scratches
-all mounting brackets/bolts included
Side-skirts - $35
-Some scratches
-mounting brackets included
-They are the ones next to my car not the ones on it
Antenna - $15
Windshield wipers - $10
Eyelids - $10
-Mugen style eyelids for '96-'98 civic
-Painted Granada Black but need to be repainted
Front Shocks - $30
-No forks, only stuts and sprigns
Enkei rims w/NT555 tires - $900
-17" Enkei RF-1 rims w/OEM centercaps
-205/40-17 Nitto NT555 ZR tires
Rims w/winter tires - $350
-14" Black steel rims made by Unique (like new)
-W404 winter tires (like new)
I'm selling my PS2 games, memory card and a light gun - <FONT SIZE="2"><FONT COLOR="red">$50</FONT></FONT> for all of it.
2. Gran Turismo 3
3. Auto Modelista
4. Ridge Racer V
5. Gadget Racers
6. PS2 Sony 8MB memory card
7. PS2 light gun w/recoil action and laser sight
<FONT COLOR="orange">////////////////////////////////////////////////////////////////////////////////////</FONT>
I'm looking to trade for the following parts (to trade, not to buy)
I need:
- D-series EX/Si 5-spd transmission w/brackets
- D-series Starter for 5-spd w/both bolts
- D-series clutch lines
- D-series clutch w/pressure plate (new/like new)
- D-series fly-wheel (new/like new)
- 2-Wire IACV sensor (preffer with a plug)
- Throttle body for 5spd
- P2P ECU or P28 w/OBD2a-OBD1 jumper harnes
- '99-'00 Si rear sway bar w/endlings, brackets and bolts
- '05-up OEM RSX type-S muffler
- HX rims with/good tires
- GSR rims w/good tires
- '02-'05 5spoke EX rims w/good tires
Old Jul 31, 2006 | 04:52 AM
thapimpfromchi's Avatar
stuff for sale in sig link.
Old Jul 31, 2006 | 05:29 AM
89crx1184's Avatar
FS:
eg vx 5 speed transmission it has about 100k on it $100 obo
high flow cat out of eg $50
SPW rear strut bar for 88-00 civic $30
Old Jul 31, 2006 | 05:48 AM
Sho Pow's Avatar
check sig for sale sale thread
Old Jul 31, 2006 | 06:02 AM
LUXXXX's Avatar
Default Re: (Sho Pow)
WTB: 94-97 teg front pass fender in silver
Old Jul 31, 2006 | 06:14 AM
ken00si's Avatar
Default Re: (LUXXXX)
subscribed
paopao's Avatar
FS:http://hondamarketplace.com/zerothread?id=1703475
WTB: Civic/CRX Si transmission ASAP.
Old Jul 31, 2006 | 07:18 AM
chubz0r's Avatar
Default Re: (paopao)
<U>WTB:</U>
-13" rims for slicks
Let me know what you guys have.
<U>FS:</U>
-vortech 12:1 fmu $75obo
-vortech bov $100obo
-missing link $50obo
-gm 3bar $60obo
-blitz sbc-id boost controller (silver) $350obo
Parts off my 01 gsr
-rear wiper assembly bo
-stock gsr intake manifold (no sensors) bo
-(x2)Rockford Fosgate Punch P5002 Car Audio Amplifier $250obo
*brand new, never used, still in wrapping, retails for $320
PM Me if interested. I can get pictures upon request. I also accept emails. iconz116@hotmail.com
Old Jul 31, 2006 | 08:05 AM
AFTERZERO's Avatar
Default Re: (chubz0r)
Koyo full core radiator will fit ek dc or eg with slim fan...............................275.00
Mitsu evo front intercooler .................................................. ......................75.00
Old Jul 31, 2006 | 09:21 AM
Mrcrx28's Avatar
Default Re: (AFTERZERO)
All from 98 ITR: front and rear sway bars
1" brake booster and master cylinder
complete rack and pinion
tein s-tech springs on stock shocks with about 70K
rear lca's.
Offer me prices on these!!!!!!
Old Jul 31, 2006 | 11:24 AM
94sisol's Avatar
Default Re: (Mrcrx28)
Corbeau Racing Seat - $100
Auto Integra Gauge Cluster - $50
Manual Integra Gauge Cluster - $100
B18A Head/Block (broken mount) has ARP Headstuds - $250
Drag Turbo Manifold (needs flange welded) - $50
DSM Bov on Piping - $100
Manual P05 Ecu - $50
Stock Gsr Intake Manifold Bare - $30
D Series Axles - $75
Stock B Series & D Series Header - $20 each
14" Steelies w/ Blizzak Winter Tires - $150
13" Tires w/ Decent Tread - $40
14" Accord Hubcaps - $40
13" Civic Hubcaps - $40
Autometer Tach w/ Shift Light - $150
Autometer Boost Gauge - $40
Del Sol Seats w/ Red Stripe - $250
DA Integra Interior (dash messed up) - $150
Fluidamper Harmonic Balancer (race only) - $300
10" JL Audio Subwoofer (bad condition, got free, supposedly works) - $20
Spyder Paintball Gun w/ Mask - $50
GT Performer Bicycle - $150
Any questions you can PM me or hit me up on AIM - CrAzYtOwN69PiMp.
Old Jul 31, 2006 | 11:35 AM
Bee17hatch's Avatar
wtb: driver side headlight for 99 civic coupe and
alternator for 90 civic lx
Old Jul 31, 2006 | 11:55 AM
Mooneyes13's Avatar
in.
d16z6 full swap minus ecu. 100k miles. virgin. ex tranny w/ no grinds. $400. come pick it up.
Old Jul 31, 2006 | 12:07 PM
mexicanstud's Avatar
WTB: Hasport or Innovative billet mounts for a b-swap into a eg hatch
pm me if u guys have anything...
Old Jul 31, 2006 | 12:15 PM
Dirty Underware's Avatar
Default Re: (mexicanstud)
WTB: 99-00' Civic fb Lip! in decent shape; doesnt have to be perfect.. willing to pay $50 at most for a used one, depending on its condition.. preferrably lookin for a Mugen style one, but open to the Type R one.. entertain me
Old Jul 31, 2006 | 12:25 PM
HondaEJ7's Avatar
WTB:
GSR Blades or SI rims or 16 inch rims with some nice tires. CASH IN HAND PM ME!
Old Jul 31, 2006 | 01:13 PM
RCautoworks's Avatar
FS: B series log manifold, external gated $210
Ported flange shown, selling non ported flange ones
Old Jul 31, 2006 | 01:38 PM
boost junky 71's Avatar
Default Re: (90blackcrx)
My Garage Sale/Trade.
http://hondamarketplace.com/zerothread?id=1589571
Old Jul 31, 2006 | 01:42 PM
.Beaver's Avatar
Bloody Beaver
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">FS: B series log manifold, external gated $210
Hey are any of your mani's AC compatible? (B series)
Old Jul 31, 2006 | 01:43 PM
DaNnYsEvEn's Avatar
up for sale:
dynomax turbo muffler 17733
came off my my ef hatch. you can use the muffler for other vehicles as well.
30 bucks for the whole axle back and muffler tip
kinda dirty looking but il clean it up, no rust!!
Old Jul 31, 2006 | 02:25 PM
M3LVIN's Avatar
Selling a Edelbrock VictorX Intake Manifold off of a SOHC OBD2 motor. Part # 4757. Shoot me an offer!
Old Jul 31, 2006 | 02:32 PM
Default Re: (.Beaver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Beaver &raquo;</TD></TR><TR><TD CLASS="quote">
Hey are any of your mani's AC compatible? (B series)</TD></TR></TABLE>
Yes, if you want them to be. I can gurantee they will clear the a/c compressor. A little fan fitment my be needed depending on how big the turbo you are running is.
Old Jul 31, 2006 | 02:48 PM
FS:
-1" master cylinder(off a 98 gsr)
-40/40 prop valve(off a 98 gsr)
RapeV-8's Avatar
f/s crx jdm back seats $160
