cam swap
Old Jul 31, 2006 | 03:45 AM
ef-b16sedan's Avatar
Default cam swap
i'm new the b-series engines. i have a b16 with no mods other than cai and exhaust (for now just swapped it in) i'm buying a set of gsr cams, they don't come with cam gears. my question is can i use the gears from the b16 cams on the gsr cams?
Old Jul 31, 2006 | 04:11 AM
civicstar's Avatar
Default Re: cam swap (ef-b16sedan)
yes, stock B series cam gears are basically the same
Old Aug 4, 2006 | 03:51 AM
i know that these cams are basically a direct swap in, but when i put the gsr cams in i'll have to readjust all the valves again right?
Old Aug 4, 2006 | 10:44 AM
civicstar's Avatar
since your going from b16 cams to gsr cams, its a good idea to adjust the valves. i suggest whenver you take cams out and put anything back in, adjust it to the correct specs.
Old Aug 4, 2006 | 03:18 PM
Default Re: cam swap (civicstar)
do you know the correct specs to adjust them to?
Old Aug 5, 2006 | 05:07 PM
civicstar's Avatar
here they are
intake: .006 - .007
exhaust: .007 - .008
Old Aug 6, 2006 | 01:22 PM
thanks
jdmasfuk
Dec 7, 2009 04:15 PM
litovi3tboi503
Feb 3, 2007 06:12 AM
slowcrxsib16
20
Mar 4, 2006 10:02 PM
unclepowers
Sep 23, 2005 10:27 AM
granada_sun
Mar 25, 2003 02:53 PM
