Installing Apexi-WS
My new Apex-i WS catback exhaust just arrived in the mail (I've got a 94 GSR). Has anyone installed one of these before? Will I need any other parts besides those included with the exhaust--gaskets, bolts, flanges, etc? I just want to be sure I have everything I'm going to need before the old exhaust comes off. Thanks.
Mark
Mark
I just put mine on not too long ago (About 3 weeks ago). It's pretty easy, just basically unbolt the old one and slap the new system on. It includes everything you need.
The hardest part will be taking the bolts off of your catalytic converter. Mine was totally fused/rusted on. It didn't matter since I was going to be running a test pipe though.
Some advice (might be obvious, but hey): WD-40 up those exhaust hangers. It makes thing a lot easier. Everything will just slide on and off without having to spent 15 minutes per hanger prying at it with a screwdriver.
And of course be safe and use some good jackstands. A buddy to help you is nice too.
Good luck.
EDIT: Oh, and as you do the install, keep the rear muffler section and tip covered up with the bubble wrap that it came with. It WILL hit the ground at least once when you're trying to get the damn thing in. You don't want to scrape up that nice shiny finish.
[Modified by shamoo, 3:21 PM 4/23/2002]
And of course be safe and use some good jackstands. A buddy to help you is nice too.Good luck.
Also, make sure you have jackstands that will support your car high enough. You'll want as much clearance as possible.
>> Just wondering where you got your WS, and how much you paid...thanks. <<
I got it at Options Auto (www.optauto.com), and paid $383 plus shipping (around $440 total).
Mark
Mark
Thats the exhaust im gonna be getting here when i get enough money.. i still owe my dad 6800 for the car and then the 400 bucs tax on it.. :\ so it may be a while.. since i will only get about 6000 for my Corolla and i have about 1300 right now in the bank.. hope to get one soon though..
it will be easier if you unbolt the cat from the header then remove the exhaust from the cat. my bolt were very rusted at the exhaust and cat connection and this is what i had to do.
Mark
Mark
$441.22 shipped to Canada from Fusion-Racing.com, so it'll probly be a little cheaper if you're in the states.
Check out groupbuycenter.com for the info on it: http://www.groupbuycenter.com/buy.asp?row_id=5229
as a lot of ppl have said the CAT bolts are really hard to get off. unbolt and unclip the O2 sensors from the cat and take the entire assembly off from the header. what i had to do was take off all the heat shielding from near the cat and piping. even though i WD40ed the bolts they didnt budge. theyre 14mm bolts so i bought a 13mm socket and used a hammer to hammer the socket to the bolt, then put the wrench on and gave it a swift kick. bam, all done. hope this helps, it took me a hile to think of this, hahaha. gl
5lugSlug
Mar 18, 2006 03:20 PM
dohcdelsol
Apr 8, 2004 12:31 PM
au-gsr
Nov 13, 2002 04:37 PM
