building a d16z6 need feedback on parts
ok i want to build a strong top end to eventualy run a strong turbo. springs i was thinking supertech,same with the valves probably stainless, titainum if i can aford them. the cam seems to be between skunk2 and crower dont know if i should go stage 1 or 2 probably 1 for now this will be a daily driver. i will also run oem d16y8 intake and throtle body that i will port match with the head. give me some feedback i think this sounds like a strong set up for now. also what is everyones feelings on skunk2 springs and the cower springs. afteri build the top i eill build the bottom end and add turbo
why zex over crower or skunk 2 i see price is lower i dont hear good things about zex springs i think super tech is good do you have an opinion on thoes or something better as far as valves go super tech stainless nitrate coated or ferera has some good ones but they are like 4 bills for ferera.
Well i've heard awesome review on both the crower stage 2 and the ZEX 59300cam which is also know to be a CompCam also.....those two cams make really good power IDK about the skunk2 cam plus it only comes as a stage 1 cam only...
its entirely up to you what valvetrain you want to go with but id suggest go with the same as for the springs valves retainers so you can get them all in the same place. im still looking into my valvetrain and havent decided where to get them yet.
TonacoJDM
10
Oct 5, 2013 07:09 AM
wfocrx
Sep 6, 2007 08:35 AM
