Rust problems
Old Jul 30, 2006 | 07:18 PM
MJPana's Avatar
Default Rust problems
so im cleanin my car today, notice a bit of rust in the usual spot, driver side right in front of the rear wheel on the bottom. typical area where water could accumulate and such. seemed like only surface rust, so i would just clean/sand/repaint. started cleanin, and either im one hell of a strong guy or that metal is just f**ked, cause now i got a rust spot and a nice hole in the center of it. anyone got any suggestions as to how i can fix it without it lookin like ***?
Old Jul 30, 2006 | 08:38 PM
vlc92189's Avatar
bondo? or take it to a body shop :-p
b16ej1lsd's Avatar
if i was you i would just leave it alone and save your money to pay a body shop to repair it the right way.
Old Jul 30, 2006 | 08:57 PM
Syndacate's Avatar
Default Re: (b16ej1lsd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ej1lsd &raquo;</TD></TR><TR><TD CLASS="quote">if i was you i would just leave it alone and save your money to pay a body shop to repair it the right way.
Ya, I had a similiar problem just w/o the hole...in the typical rust spot
Luckily I just totalled my car and was able to take some of the hood out and weld it back in..though I had to take it to my friend in a bodyshop for him to make it look like it was part of the car...looks perfectly stock OEM btw, just a bit thicker if u look at it from underneath b/c it's the hood metal :-P
But anyways, cut/weld - but like I said, you need a bodyshop to get it to look perfect - and you can always find bashed up hoods in junkyards to cut off of :-\
Worked for me
Old Jul 30, 2006 | 09:32 PM
instrument's Avatar
you know why that spot rusts, cause theres nothing protecting the underside, the first thing i do on all my honda is sand the underside and paint the **** out of it.
having had five civics/crx's i've learned the hard way.
the problem is you're sanding the outside, when the rust is coming from theunderside.
goodluck, try some of those quarter panel rust repair pieces, they have em on ebay.
slocar
Jun 10, 2006 06:59 PM
NXLude
Oct 11, 2005 05:21 PM
2s10w4u
Jun 11, 2005 11:02 PM
88 rex
Welding / Fabrication
15
Feb 16, 2005 01:25 PM
Race Egr
Nov 5, 2004 03:41 PM
