Alarm system problem
Old Jul 30, 2006 | 05:10 PM
ir0nmanx's Avatar
Default Alarm system problem
I bought my car months ago with a Viper alarm system and it worked great. Now its not as sensitive as before, It feels like its getting weaker and weaker. How can i get it to be as sensitive as before? Is it dying?
Old Jul 30, 2006 | 05:43 PM
94_DC4's Avatar
Default Re: Alarm system problem (ir0nmanx)
Whta exactly do you mean getting weaker? Is the signal for the remote getting weaker or are you referring to sensitivity of the alarm.
Old Jul 30, 2006 | 05:48 PM
ir0nmanx's Avatar
Default Re: Alarm system problem (SiRGDC)
The sensitivity is getting weaker, before anything would set it off but now it doesnt even go off at all.
Old Jul 30, 2006 | 06:18 PM
94_DC4's Avatar
Try adjusting the sensitivity of the shock sensor. But you dont want it too sensitive because then you will be getting false alarms.
Old Jul 30, 2006 | 06:32 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I have a spare shock sencer, If yours is bad come pick it up. But I doubt it, Out of all the years I have be doing alarms thoses are the last to go, I have only replaced two, one was broke and the other got kicked or something.
Old Jul 30, 2006 | 09:28 PM
ir0nmanx's Avatar
Default Re: Alarm system problem (wrx-killer-Sti eater)
Sorry but I'm a noob at this so I dont know how to adjust it and I dont even know where it is.
Old Jul 31, 2006 | 04:24 AM
B18C_EJ8's Avatar
Well, you could begin by looking under the dash on the drivers side... DEI shock sensors like to be zip tied to a wiring harness. They're a little rectangular box made of clear plastic, and a red LED will illuminate if you tap it...
There's an adjustment pot on it, too, and it should be labeled + and -... Turn it GENTLY with a small screwdriver toward the + to increase sensitivity... Turn it only a degree or two each time and test after each adjustment. When you reach the desired level of sensitivity, you're done.
Old Jul 31, 2006 | 08:36 AM
ir0nmanx's Avatar
Default Re: (B18C_EJ8)
Alright Thanks I'll go try it.
mechanix619
Audio / Security / Video
Dec 2, 2010 05:02 PM
npmartin
May 8, 2010 07:39 PM
tlarimer
Feb 18, 2010 04:43 PM
forumnoobie
Jan 8, 2007 03:37 PM
