92 civic cx wiring harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja »</TD></TR><TR><TD CLASS="quote">So if you wanted a 4 wire O2 wouldn't the teg harness be good? then you could wire the shock tower back for the other O2 wires??</TD></TR></TABLE>
it is already wired from the shock tower back, just the engine harness has the single wire o2. so just get the integra harness and plug it in and you are good to go. but if you running vtec then you are gonna have to wire up vted and knock and iab and stuff
So basically the 92-95 ex/si harness will have vtec and 4-wire O2 already built in.
The 92 cx has vtec to the shock tower and also 4-wire to shock tower?
If so then my swap just got easier with the ex/si harness I am getting.
SWEEEEEEEEEEEEEEET!!!!!!!
Nope no gsr stuff here.
That is better that I just have to install my wire harness and start engine. I was going for a stock look without running extra wires this. Splice/solder that.
My swap just got a little better.
johnxjohn26
Apr 22, 2007 08:07 PM
Lei Siew Long
Jul 12, 2003 11:05 AM
