omni power lca
I was wondering if a set of omni power rear lower control arms for an eg would fit on a 90 si. ive read that they are the same and that the skunk 2 lca's fit but on omni power's website it just say's eg and dc's. can any one help cause my brother has a set im thinking of picking up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack »</TD></TR><TR><TD CLASS="quote">they aren't designed for an EF but they work fine. They are 1/16th too long which will change your camber by a small amount.</TD></TR></TABLE>
I have a set of each and i run eg control arms on my crx now. get the eg arms line them up with the stock arms and put bolts through the inner and outer holes, they line up perfect they are NOT 1/16 off, even the itr/88crx style are the same i have seen them lined up and are identical
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chitown_ef9si »</TD></TR><TR><TD CLASS="quote">another question would my stock sway bar fit or woould i need to replace it?</TD></TR></TABLE>
stock bar will fit you might need to buy new bolts ( i needed longer ones) to hook up to the new arms though
a 1/16" difference would be easily achieved in worn bushings anyway.
eg and ef arms are the same geometry as far as i can tell.
EG on top (no swaybar holes on any EG LCA)
EF on bottom
Modified by Tyson at 5:38 PM 7/31/2006
EF on bottom
Omni lca's work fine, but I have heard bad things about their bushings. I have a set on my sedan and have noticed some noises in the rear so I need to get under there and check it out.
As far as cost... I think they run around $100?
Slade Exulis
May 11, 2016 02:47 PM
Power Rev Racing
10
Jun 10, 2005 03:06 AM
mambajunkie
Feb 20, 2004 09:00 AM
