Can I remove these 2 AC compressor bolts w/o discharging AC? *Pic*
I'm trying to remove the windshield reservoir tank. It will not fit through the opening without removing the a/c compressor. I don't want to cut the reservoir tank but will if I have to. Is it safe to remove the compressor with the a/c still intact and charged? Car is a 95 VX. Thanks for any help!
BTW > The car is my weekend toy which is why I am removing all the unnecessary parts.
If you remove bolts 1 @ 2 then you will lose pressure in a/c system most likely.
You can remove your compressor from bracket and tie out of the way if you were removing engine or something. You would be safe doing that.
But I think your problem is, if you are wanting to remove the resevoir to your windshield washer fluid then just separate the filler tube from the bottom holding tank. Take the tube up through the top and the tank under the car. This should answer your question.
That thing with the numbers is call an A/C drier. It is needed for your A/C system kind of like a filter.
Hope this helps.
Hope this helps.
That looks like the dryer, in which case removing those bolts (the ones labled 1 & 2) would vent the system.
Ok sorry reread post.
If you are wanting to take out your complete A/C system then I would find someone that will take your freon for free. Tell them you just want to discharge system and they can keep your freon for payment. If you know any shops then you should be able to get this done.
Then you can gut your complete a/c system.
If so I may want to buy some parts for the A/C system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja »</TD></TR><TR><TD CLASS="quote">If you remove bolts 1 @ 2 then you will lose pressure in a/c system most likely.</TD></TR></TABLE>
I was worried it may blow up if disconnected with the system charged
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">But I think your problem is, if you are wanting to remove the resevoir to your windshield washer fluid then just separate the filler tube from the bottom holding tank. Take the tube up through the top and the tank under the car.</TD></TR></TABLE>
I did not notice that the tank seperates into 2 parts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">This should answer your question.</TD></TR></TABLE>
Thanks, I'll take a look in the morning
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">That thing with the numbers is call an A/C drier. It is needed for your A/C system kind of like a filter.</TD></TR></TABLE>
Hahaha..... learn something new everyday.
Thanks for the info
Thanks for the info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch »</TD></TR><TR><TD CLASS="quote">
BTW > The car is my weekend toy which is why I am removing all the unnecessary parts.</TD></TR></TABLE>
Then why are you keeping AC?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. »</TD></TR><TR><TD CLASS="quote">Then why are you keeping AC?</TD></TR></TABLE>
Because he doesn't understand the concept of a track car.
And yes, OP, if you disconnect the hard lines from the drier/dessicator you will blow all the R134A or R12 out of your system and be breaking the law.
Because I have not purchased the K20 yet
you would only be breaking the law if you have r12 an your car should be r134 i have the same year and model
floriudabrain
Jan 13, 2006 10:56 PM
MugenHonda
Oct 7, 2005 08:16 PM
