ever heard of a 99mm b series crank?
Old Jul 29, 2006 | 11:38 PM
jdmek909's Avatar
Default ever heard of a 99mm b series crank?
i have a stroked motor and i wasnt sure wat exactly the size it was. i was told from the previous owner it was 85mmx99mm crank. He said it was made by golden Eagle. I measured the deckplate and its a 1 inch deck plate. i got a 85mm head gasket and put it on there and the piston seems to be 85mm. do you guys think it would be 95mm or could it be 99mm. i just wanna know if you guys have seen a 99mm stroked b18.
Old Jul 30, 2006 | 03:26 AM
NJIN BUILDR's Avatar
Default Re: ever heard of a 99mm b series crank? (jdmek909)
Golden Eagle doesn't make cranks but they may have done the deck plate.Eagle makes cranks but only to 95mm max.If you have the head off then just measure the stroke.Bring a piston to tdc and measure from the head gasket surface to the top of the piston.Now measure from the head gasket surface to top of the piston on one of the cylinders thats at the bottom of the stroke.3.740 is 95mm (3 3/4").3.900 is 99mm .
Toanz
Engine Machining & Assembly
Apr 3, 2016 08:12 PM
BenS579
Aug 19, 2014 03:35 PM
Xathine
Apr 18, 2012 10:50 AM
asubennett
Jul 14, 2005 06:44 PM
