oil smell like gas
If your timing is advanced too far you'll run rich. If you don't have a Haynes manual for your car, get one, and then rent a timing light from AutoZone and time your car. Or just take it somewhere and have it done.
Might wanna check for a stuck injector. When you turn off the motor the gas will leak out the injector and thru the rings, ending up in the oil.
Used to happen alot in carbed cars the float level would be set to hi and when the car is off it would do the same thing.
msinsky14
Dec 10, 2007 05:05 PM
