CEL (Dash) Rapidly Flicking - Fuel Pump SOMETIMES Primes - Car Wont Start - Motor Swap
Old Jul 29, 2006 | 07:10 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default CEL (Dash) Rapidly Flicking - Fuel Pump SOMETIMES Primes - Car Wont Start - Motor Swap
The car is an 88 Crx si, d16a6 motor fully built, running dsm 450's and turboedit and a 2.5 bar map sensor. I snapped my timing belt so I swapped the motor today for another built a6.
No changes were made anywhere, straight swap. Got it all back together, go to start the car and the fuel pump primes, try and start the car and it dont work, crank and crank and cranks, throws a few little exhaust blips.
Turn it down and try again, CEL on dash is now kinda flickering, slows down and then flicker faster, I check the ecu code, cant read it, damn thing it changing speeds on its flashes, sometimes rapid, sometimes slow, but it would pause at points.
I check the motor, everything seems mint, look harder........
BROKE THE MAP SENSOR
Little itty bity 2.5bar has these little prongs and everyone of them broke out, 3 of them. ****!
Cant do anything.
My question is, nothing was changed in the swap, other than breaking the map sensor, but would it cause the motor to do the things that I am describing?
Or is something else the matter?
Hope someone can help
Thanks
Old Jul 29, 2006 | 07:17 PM
jeremydde's Avatar
Default Re: CEL (Dash) Rapidly Flicking - Fuel Pump SOMETIMES Primes - Car Wont Start - Motor Swap (PINKS)
You probably have a bad ground. Check that the ground is properly secured to the thermostat housing, and all engine to chassis grounds have been connected, and are not corroded.
Old Jul 29, 2006 | 07:18 PM
E_F_9's Avatar
thats what i would say too
PINKS's Avatar
Default Re: CEL (jeremydde)
very might well have forgotten that one, Ill check it for sure, i did it with a friend, I dont remember doing that one myself but I forget if I looked or not
Old Jul 29, 2006 | 07:19 PM
PINKS's Avatar
Default Re: CEL (PINKS)
would that cause the fuel pump to prime or not prime though? CEL flickerring?
Old Jul 29, 2006 | 07:24 PM
E_F_9's Avatar
if its not grounded good yea
Old Jul 29, 2006 | 07:31 PM
jeremydde's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">would that cause the fuel pump to prime or not prime though? CEL flickerring?</TD></TR></TABLE>
It absolutely would act just as you described it.
Old Jul 29, 2006 | 07:36 PM
E_F_9's Avatar
and make sure the battery is connected good and tight
Old Jul 29, 2006 | 07:40 PM
PINKS's Avatar
Default Re: (MaD_VTAK)
battery ground is mint, 4 gauge as well as the valve cover
But the fuel pmp wont even prime is the thermo isnt grounded?
Old Jul 29, 2006 | 07:46 PM
jeremydde's Avatar
Default Re: (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">battery ground is mint, 4 gauge as well as the valve cover
The thermostat ground is the electrical harness ground, and the main relay which controls the fuel pump shares that ground point. If that ground is poor, or not connected, then yes the fuel pump won't prime. The ecu sends a signal to the main relay to trigger the fuel pump, but the main relay can't click over to prime the pump if it has no ground.
Old Jul 29, 2006 | 07:50 PM
PINKS's Avatar
Default Re: (jeremydde)
I like you
lol, thanks bud
Old Jul 29, 2006 | 07:51 PM
jeremydde's Avatar
Default Re: (PINKS)
LOL No problem, let us know how it goes.
Old Jul 29, 2006 | 08:22 PM
Tippyman's Avatar
Default Re: (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">I like you
lol, thanks bud</TD></TR></TABLE>
Old Jul 30, 2006 | 11:26 AM
E_F_9's Avatar
lol
Old Jul 30, 2006 | 11:30 AM
jeremydde's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
Nice.
Neckbeard
Nov 14, 2018 02:46 PM
TimKennard
Jan 2, 2011 10:04 AM
obijuankanobi
Dec 11, 2005 11:52 PM
