blown head gasket 10 min after start up?
Old Jul 29, 2006 | 06:51 PM
Day-DayC's Avatar
Default blown head gasket 10 min after start up?
just what it says put engine together got all air pockets out of the motor pull it out of the shop not passing 3000rpms and next i hear gurgling from the over flow can, pop top off the radiator and top it off(coolant) nothing but tiny air bubbles and over heating after 1500rpms has this happened to anyone?
Old Jul 29, 2006 | 07:28 PM
nsxmatt's Avatar
Default Re: blown head gasket 10 min after start up? (Day-DayC)
Head gasket upside down?
Old Jul 29, 2006 | 11:50 PM
turbotime's Avatar
Default Re: blown head gasket 10 min after start up? (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Head gasket upside down?</TD></TR></TABLE>
and any leaks? coolant or oil?
Old Jul 29, 2006 | 11:58 PM
abnaasefmb's Avatar
Default Re: blown head gasket 10 min after start up? (turbotime)
what engine
Old Jul 30, 2006 | 12:40 AM
cutt's Avatar
I hear gurgling in my over flow tank sometimes and it doesn't overheat
Old Jul 30, 2006 | 04:50 AM
Chiovnidca's Avatar
Did you check the head and block surfaces with a stright edge?
Old Jul 30, 2006 | 05:26 AM
dsmdan's Avatar
Probably didn't get the headgasket on correctly.
Old Jul 30, 2006 | 06:07 AM
narfdanarf's Avatar
Default Re: (dsmdan)
Happened once with a dropped sleeve.
Old Jul 30, 2006 | 07:11 AM
DRAGLS's Avatar
Default Re: (narfdanarf)
first thing do a leak down.
Old Jul 30, 2006 | 02:21 PM
Day-DayC's Avatar
HEAD GASKET WAS CORRECT, BLOCK WAS JUST SLEEVED, HEAD WAS JUST MACHINED. ITS ON A LS/VTEC. IM PULLING THE HEAD OFF MONDAY. ITS JUST A LTTLE PUZZELING
Old Jul 30, 2006 | 03:01 PM
Chiovnidca's Avatar
leakdown test?
Old Jul 30, 2006 | 03:12 PM
xsi-t's Avatar
this happened to me yesterday and it was a bad rad cap
Old Jul 30, 2006 | 05:52 PM
Topdawgg's Avatar
mine was doin that, and i tightened the tabs on my rad cap, and it stopped
Old Jul 31, 2006 | 01:34 PM
Day-DayC's Avatar
did a leak down test shows good no bubbles from the radiator what gives im in the dark
Old Jul 31, 2006 | 02:10 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Day-DayC &raquo;</TD></TR><TR><TD CLASS="quote">did a leak down test shows good no bubbles from the radiator what gives im in the dark</TD></TR></TABLE>
50/50 coolant mix? Air bled from system? T-stat good? Rad cap leaking?
Old Aug 1, 2006 | 07:10 AM
Day-DayC's Avatar
FOUND THE OVER HEATING ISSUE THE TWO HOSES ON THE BACK OF THE MOTOR WAS CROSSED BUT STILL HAVE THE GURGLING THING AND AT MOMENTS IT THROWS UP COOLANT
Old Aug 1, 2006 | 09:39 AM
Flashmn's Avatar
sounds like headgasket / block-head mating issues to me.
Old Aug 1, 2006 | 12:29 PM
Day-DayC's Avatar
Default Re: blown head gasket 10 min after start up? (Flashmn)
both were decked before put together. (head & block)
flozella
Aug 30, 2014 07:20 PM
ghozt107
Jul 25, 2010 10:14 AM
Squirtin EGsr
17
Sep 26, 2005 09:13 PM
YellowCivicE
Jul 11, 2004 12:59 AM
GSR4door1
Apr 24, 2004 08:02 AM
